ANYTHING NEW ON THE MOBIL 1 FRONT?
#286
I run it in an old vw of mine that has low oil pressure when hot, which it does provide a nice boost over even a thick 20w50. The other engines I've used it in have either had worn rings or bad valve guides and it's a great band aid to clearing up most of the symptoms.
#287
my friend has a 2003 nissan truck, uses mobil 1 oil after break in from new and had the truck since day one. truck has 97,000 miles, always changes oil every 3000 miles. i was talking to him about oils and how mobil 1 is not the same.
he said he has been using it since he has had the car and is not changing, no matter what anyone says, he says the internals look like new.
well to make a long story short. he had his a/c compressor belt changed and i thought i would take a look as he said it was a pain to change. my real intension was to look at his engine. i asked if i could open the oil cap, he said yes as he was proud how clean the engine was inside. he has overhead cam so you can see 2 lobes when the cap is off. mind you the oil cap was clean and the internal aluminum was very clean also, but the cam lobes were all scratch up, not a little but a lot in my opinion, never seen a lobe that looked like that. i did not want to say anything and just commented on how clean it was. sometimes you cannot be be honest as if i were to point it out he would have dismissed it. so might as well not say anything.
so take it for what its worth and you make the decision on what oil to use for your car.
but if you take what Charles and Steve are saying it appears to me more than clearl that they have a point.
its funny you have actual testimony from peole that have test equipment and people that worked on these cars and still you want to angle around trying to find an altenative to whats suggested. now mind you they are not some nobodys that are pulling this stuff out of the hat. i am too subjective but this is a no brainer to me. my friends nissan cams showed me the this. now do not get your panties in a knot. i am just very direct and write that way and do not sugar coat . if its crap then its crap, if its good then good. no sense of putting icing on crap, will not fool for long.
dutch
dutch
#288
Charles & Steve,
Just wanted your opinion of Valvoline motocycle oil. I believe it's a SJ oil priced below $6 a Qt, and local NAPA stores
carry it. I'm thinking of using it in my '88 944S, and saving my Swepco for my 993.
Their website states:
"Minimize Wear - Increased anti-wear agents (zinc and phosphorous) help minimize wear from metal-to-metal contact.
Prevent Foaming - Silicone additives to prevent foaming and help maintain proper lubricating film. "
I've never heard of silicone additives in a motor oil before. Good or Bad ??
What do ya'll think of this for my 944S ?
Thanks,
Glenn
Thanks,
Glenn
#289
Silicon is a common anti-foaming agent present in most oils. I haven't looked at it closely, but in a pinch, I'm sure it's a better choice than 95% of the other oils in Napa, Autozone, or any other local parts store. It might be worth doing a VOA on it to see how it's formulated and might be an easy option for those who want something local.
#290
Charles, Thanks for the quick reply !
I did a search after posting my question and found this, (forgive me if this has been posted before):
http://advancedlubetech.com/USD/amsoil/pdfs/g2156.pdf
Its an AmsOil pdf with test of motorcycle oils. Looks like they place the Valvoline 4-stroke 20w-50 somewhere in the lower middle of the tested oils. Looks like they place their product and the Mobil 1 Motorcycle oil in the upper (better) ratings.
All in all, looks like the Brad Penn and Swepco are still the answers, even if not locally convenient.
Glenn
Glenn
#291
Just changed my oil - shop used Mobil 1 - now am thinking about replacing. How about draining and refilling with one of the recommended oils, without replacing the filter? any thoughts? I figure the filter's still clean, but a little Mobil 1 might not be an issue in an otherwise well-lubed car. Or should I just have it all changed and ring up another bill...?
#292
The Rotella T synthetic 5w40 is still the old, CI-4 rated version (at least as far as I know). You should still be fine. That said, once they phase out that product too, I would just stick to a CI-4 rated oil for a pre-2007 diesel engine, as recommended by a few different fleet service magazines. Just as with our Porsches, Swepco 15w40 would be an appropriate for your cummins.
#293
#295
http://www.germanautoparts.com/beta/...0additives/ELF
I found a source for ELF/Total. No affiliation, blah, blah. May be a little expense. For me it's local so I can save on shipping.
#296
some new info on the new M1:
http://www.bobistheoilguy.com/forums...22#Post1056922
And an interesting comparison between the V-twin and the M1 15-50:
http://www.bobistheoilguy.com/forums...041219&fpart=2
Personally I feel a bit better with the results above continuing to use the M1...
Here's a VOA provided by CTC Analytical Services of Phoenix, AZ and reported in a recent issue of Full Throttle magazine:
Silicon: M1 15W-50: 9ppm
Boron: M1 15W-50: 228ppm
Sodium: M1 15W-50: 13ppm
Magnesium: M1 15W-50: 43ppm
Calcium: M1 15W-50: 2464ppm
Phosphorus: M1 15W-50: 1193ppm
Zinc: M1 15W-50: 1315ppm
Molybdenum: M1 15W-50: 90ppm
Here are the numbers as posted in the article referenced above:
Silicon: M1 15W-50: 9ppm M1 V-Twin 20W-50:10ppm
Boron: M1 15W-50: 228ppm M1 V-Twin 20W-50: 188ppm
Sodium: M1 15W-50: 13ppm M1 V-Twin 20W-50: 3ppm
Magnesium: M1 15W-50: 43ppm M1 V-Twin 20W-50: 538ppm
Calcium: M1 15W-50: 2464ppm M1 V-Twin 20W-50: 1899ppm
Phosphorus: M1 15W-50: 1193ppm M1 V-Twin 20W-50: 1142ppm
Zinc: M1 15W-50: 1315ppm M1 V-Twin 20W-50: 1352ppm
Molybdenum: M1 15W-50: 90ppm M1 V-Twin 20W-50: 0ppm
#299
That said, there's evidence to say that Mobil 1 0w40 is fine for new Porsches, as long as the drain intervals are shortened even more than the 12k recommended by Porsche. That is not what is at debate here. It's this same oil in the older engines that I'm talking about.
This was already posted on the Pelican thread, but I'll point out the difference again for those who haven't seen the other thread:
*in the V-Twin
and
*in the 15w50.
The previous 15w50 prior to this whole oil debacle had a detegent formulation like the current V-twin, with actually even less Ca, in the 1600ppm range if memory serves correctly with the old SH/SJ formulation. That makes a big deal and greatly affects the performance of the oil, not only Zn and P #s. Even Mobil will say that the new "re-introduced" m1 15w50 isn't the same as what was sold before.
To keep it short and sweet, there are numerous SAE papers discussing how Ca detergents are needed for longer drain intervals but for wear, the previous Mg/Na + lower Ca detergents worked as well, but don't hold up for long drain intervals, something we're not concerned with.
If you really must keep using Mobil 1, just use the motorcycle formulation instead. It's the safe thing to do as it's closer to what was used in these engines new, even up to 2004 when it was an SH/SJ rated ACEA A3/B3 oil that was called for even in the new Porsches per the owner's manual.
*in the V-Twin
and
*in the 15w50.
#300
After reading much of the thread and talking with other Rennlisters I picked up a couple of cases of Brad Penn 20W-50 and had AiRick over to help me do the oil change.
It was my first oil change since buying the car so it was a big help having someone there who had figured all the shortcuts out.
So far I am happy with the new oil, no leaks, and we will have to wait and see on the effects over a longer period.
Great information by Charles Navarro and others on this subject.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
