??looking for tips on drop link removal??
Seared
I see. I would try to get a small amount of spray lubricant under the lip of the boot in order for it to rotate on the stud as you tighten.
Andreas
i will grind down a 16mm but i don't think that is the issue. I did some fooling around w/ my unmounted RS/Evo uprights. The only way to do it w/o stressing the boots is to spin the whole droplink. I don't think that is possible when mounted in the car.
Getting ready to try again this PM
I just checked a pair of forged C4S links ( which only have a single ball stud for the upper end that screws into the carrier) ..... and the stud was easily turned by the 16mm flats without the slightest resistance from the boot: if yours remains stubborn, I would give it a shot of spray lube as Andreas mentioned. I do recall taking them apart by turning the stud only - not swiveling the whole drop link.
Appears that you unfortunately inherited the problem one of the lot
