FS: 993 Front Window Seal
Apparently there are different window seals for early vs. late 1995's... can't seam to find the posts now. These seals are new and if they are the right ones for you, they're a good deal. The triangular insert that runs down the middle of the strip is facing in the wrong direction for my car.... check the part numbers and applications to see if they'd work for you.
