Steering improvements.... Versus a 997GT3RS
RL Technical Advisor
The EVO tie rods have a monoball on the inner end instead of the rubber coupler found on the RS and regular 993's. These function just like the 930 tie-rods used to upgrade every '69-'89 911,..... No additional NVH.
Although Porsche does not offer the inner EVO pieces separately and one has to buy the whole thing to get those inners, its an elegant and VERY durable solution.
I've done quite a few of these and the difference in steering precision and response is amazing.
Steve - any street goodness going with a non-PS rack along with your suggestion??? Or is that a track-mod? I thought I read somewhere that the no-assist racks were hard to get now?
mar
mar
Coleman,
Nothing against the steering of the GT3RS, but try out a Cayman on the same roads and tell us what you think.
Not saying anything about power, chasis rigidity, grip or any other attributes, just compare the steering for us please.
BTW, great friend to loan you a RS for a few hours. The best I could do was a regular GT3 for half an hour.
CP
CP
These run $ 1250 and one needs to call the dealer to see if they are available.
I suggested welding to fix the steel hex to the rim of the barrel ( on the left as shown) ...... for I would not want to be the guy trying to dig that rubber out - it looks to be ..... formidable
The EVO tie rods mentioned would be the more elegant solution vs welding a bridge on the outboard end.
Steve W - do you have part numbers and ~ $$ for these parts??
Steve, could you please provide us with more information about these EVO tie rod for the 964/993 cars? Are they a direct bolt-in with the standard PS rack? Approx cost for the parts? Can you supply them?
It seems to me that these EVO ends with the urethane control arm bushings would really tighten up the front of the car without creating too much NVH for street use.
You have to change the uprights and at least the outer ends.
These parts
I forgot who posted this earlier comparison, stock top, RS/EVO bottom w/ monoball inner
Chris Walrad posted this one
Stock top, RS outer/inner bottom
These parts
Weathergirl
Interesting point. You read about solidly mounted steering racks more and more on newer cars. On my old STI, the rack was mounted in rubber and installing poly instead really reduced the vagueness. Later, the factory took out the rubber entirely and later STI racks are solid mounted.
I only see one part number for the rubber 993 rack mounts: 964.347.137.07 Surprising there was no "RS" version. Maybe on the 993 the rubber needs to be there for some reason?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Very interesting stuff. Looking at the pix Bill V posted gives rise to this (dumb?) question: If you've lowered your car to the point you are flirting with bump steer, would switching to the RS tie rod ends ALONE help? They seem to have slightly different geometry.
Bill wrote
That is more work and money than I wish to invest in this experiment.
Who thinks that welding the inner rod-end rubber isolator would be an effective and safe proposition?
In my mind there is no doubt that this rubber unit has a seriously negative effect on steering feel. How many different 911 models have this "feature"?
