Engine block heater option
Super Moderator
Needs More Cowbell
Needs More Cowbell
Would anyone happen to know if the 993 had an option/part for an engine block heater? Did a search and came up empty.
I have engine block heaters installed in all my cars (gas and diesel) and they make a BIG difference in the winter. Engines start at zero deg just like it's 60 outside.
Seriously Cold Starting
Here's an interesting option to consider...no affiliation.
http://www.padheaters.com/
Make sure you're not running 50-weight oil in the winter. That'll make for hard starts in the morning.
That said, do your cars really have trouble starting when it's zero out? I grew up in northern Vermont (quite a bit colder than Mass) and unless there was an old battery in the car, we never had problems, even on mornings a lot colder than zero. What is the problem you're trying to solve?
A garage is the best engine block heater there is
Super Moderator
Needs More Cowbell
Needs More Cowbell
I have a heated garage for the cars, but was curious what option was available for the times the car is not in a garage.
As always, my primary concern on a cold start is due to the oil not being quite fluid enough at start, leading to brief periods of high engine wear.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I was born and raised in Winnipeg Canada and can relate to seriously cold weather. A battery blanket will help significantly, a block or fluid heater even more so.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Super Moderator
Needs More Cowbell
Needs More Cowbell
I installed them back when I was a kid at my father's house. Fairly straightforward electrically, the hardest part is breaking up the old driveway.
Worked quite well, apart from the electric bill if you forot to turn them off.....timer is highly recommended.
