HID question: Size of Ballast for ebay 120199903766
#31
Hans - What you have is the "slim style" ballasts and you will be able to fit that into the headlight assembly easily. The black box is the ignitor (which are built into the larger, earlier generation ballasts) and those will also fit inside the assembly....you just need to manipulate the wires a bit when packing it all in as some of the cables are a bit stiff.
Thanks David.
btw - nice Cab you got there - really nice!
#32
Thanks for the compliment...it's the one I keep in LA that unfortunately I don't get to drive much lately. I have a white one in Hong Kong that is much less tricked out ...I did the HID slim ballast install yesterday and if you've read all the threads it's a pretty easy DIY. Good luck with the install
