HID lights installed - HUGE upgrade!
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Best $150 bucks I've spent on the car so far.
What a difference it makes in the amount of light around the car. I turned on the high beams and I really can't tell much difference. I need to upgrade to the bright white lights bulbs for the fog lights next, they look really dull and yellow in comparison. I already moved the Sylvania bright white H1 bulbs from the projectors to the high beam headlamp position. I think it does help keep the color closer to the HIDs. In case you are wondering what digital HID set I installed, here is the link - no affiliation, etc. http://www.dxhid.com/
Thanks to everyone for the information on installing the kit inside the headlamp case.
This link was the best for information - https://rennlist.com/forums/993-forum/336973-aftermarket-hids.html
As always, this place rocks![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Merry Christmas and Happy New Year to all!!
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Less than 1.5 hours and I really took my time - self identified perfectionist.
Thanks - the entire kit is inside the headlight assembly. Looks stock from the outside and retains all of the plug and play features of the standard car. Easy to reverse in the event of a HID failure as well. Lots of details from other rennlisters in the previously identified post.
Light pattern appears to be the same, just more full/brighter than the standard hallogen bulb. Adjusting the beam height is no different than adjusting the normal headlight assembly. The lens is the same so you just use an allen wrench to adjust up/down and left/right per the level bubble guage and the angle gauge in the headlight assembly. Hope this helps.
HID lighting is a great upgrade for our cars. I did the headlights years ago and I am now considering a HID upgrade for my Turbo S fogs ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Has anyone retrofitted the fog lights with HID projectors?
Thanks for info.Can you indicate which kit you bought.I went to the website but I could't find a kit for
$150. and I'm confused as to which to buy.
Regards
Joseph
Regards
Joseph
Yes - I was planning to use a set of Hella HID Micro DE lamps for the upgrade, however, this set is currently listed on Ebay for $450. So I may retrofit another set of Hella projectors with a HID kit for a better fog beam pattern and lower cost.
Let me know if you have any other suggestions...
Regards
Joseph
Regards
Joseph
Greg
I put Exes in mine too. Paid $149. The wiring is a piece of cake. The bulb diameters were just a hair larger than the stock bulb so I had to do some light filing with a rat tail file. Ballast fits inside the housing without a problem. I also took the lens off and cleaned it. I think I may replace them both since they are somewhat pitted on the outside. And just got done aiming them tonight. I almost feel like I'm somewhat of an expert on the 993 headlight now! Very nice upgrade.
I had to do some minor filing to get the bulbs to fit too. I thought maybe it was just my headlights being slightly off. Nice to know that someone else needed to file the aluminum down just a bit. It was not much filing and certainly doesn't effect the headlight assembly at all. I will eventually replace the exterior glass due to pitting too, but that can wait for now.
Let me know if you have any other suggestions...![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
http://trailtech.net/single_lights.html
I'm rolling those.. Stuck them way deep in the lower area of my turbo front bumper cover.. They are really nice..
C/
