WTB: 6-speed G50
WTB: 6-speed G50
Anyone have a lead on a 6-speed G50 transmission that's available?
I'd like to switch from a 5-speed to a 6-speed for my track car and am looking for a 6-speed gearbox to use as the donor to have geared the way I want. Ideally, one with only 1st gear on the main shaft.
Pete: Blue car. I've seriously considered it as it was rebuilt with close ratio gears a few years back. If I can't find a reasonable priced donor box, that is likely the route I will go. It would just feel funny with a 5-speed in the 993.
That would be nice, but the cost is likely to be stupid expensive. I'm looking to find a used box and then re-gear to the ratios I've chosen. I have a years worth of data for what speed and rpm I'm at in all the turns at the tracks I drive most often, so it's fairly easy to examine what the different gear changes would mean.
JMO, but Tom is on the right track. g50/31 is expensive and great for a street or dual pupose car but not the best for a track only car. Ideal would be a /30 or /32 w/ no gears fixed to the main shaft.
Unfortunately all but the earliest g50/20s have that fixed 1st gear problem later ones have a fixed first and second, but even w/ that regeared 2(or3)-6 is the nuts.
