Part Number Help
Part Number Help
Does anyone happen to know what the part number is for the black rubber drain hole plug(s) that are located underneath the spare tire (I believe there are 4) in the trunk ? I am missing a couple and ordered them through the Porsche dealer but they keep sending the big round metal plates that are welded to the trunk floor. Any help is greatly appreciated.
Weathergirl
Bumping this old thread. I'm missing a couple of these, too, but I can't get the part number to work anywhere--Stoddard and Pelican don't list it. The parts diagrams also don't seem to show it.
Any add'l help? Thanks!
Another alternative I found is a wheel rubber inflation valve. You cut just below the metal valve, it makes a perfect rubber funnel. You introduce the small end and pull from underneath until the metal surround goes in the groove.
regards
regards
Weathergirl
964.504.213.00 shows as being superceded by 996.504.213.00, which has in turn been superceded by 996.504.213.01, which is a 85mm diameter cover plate of some sort.
in the front frame there are two references, the other is 964.504.209.00 and is as large as the first
I got the plate twice when I ordered through the dealer and finally gave up. The plate is actually welded in the trunk area and painted body color.
