993 engine parts
993 engine parts
993 engine parts available
Hope everyone had a great Thanksgiving. I spent the morning disassemblying a 1995 993 engine. Everything is available.
case $1500, cams $300, rockers/shafts/lifers $340, cam towers $325, alternator/fan assembly $425, complete intake assembly including all fuel injectors/ wiring $1100, brain $650,rods $300
****SPECIAL Patrick lightweight flywheel, with just purchased new Competition Center Force pressure plate, disk is performance friction disk from Vertex designed to mate the 993/964 engine to 915 transmission $800
jim dorociak
jdorociak@gmail.com
805-498-7261
jim dorociak
jdorociak@gmail.com
805-498-7261
Why is there a difference between 95 and 97 pistons cams heads cylinders????
I am intrested in some spares from your engine and hopped to my PET.
95 engine parts are different than 97, I wonder what difference is there...
specifically what parts are you looking for? Heads on the later model engines have larger intake valves, do not believe there was any difference between pistons/cylinders.
I also have a set of 3.8 Mahle pistons(used in vgc) with a new set of LN engineering billet cylinders $2500, webcam 993 supersport cams --- and in a couple of weeks I have another engine due to be disassembled- it is a 97 Varioram engine. let me know exactly what you have interest in. Jim
jdorociak@gmail.com
jdorociak@gmail.com
Mark, got your email, will send pictures and respond in a while after things slow down.
I have the tin, heater pipe, cat, muffler & ...
Jim
jdorociak@gmail.com
Jim
jdorociak@gmail.com
P/C's, heads have sold -- everything else still available. lowered price on the Patrick Motorsports flywheel/pressureplate/disk combo designed for 3.6 engine into a 915 transmission $800
Is it really January 2008 already?
jdorociak@gmail.com
jdorociak@gmail.com
