993 Forum 1995-1998
OT: Ever clayed a windshield?
Old 11-07-2007, 04:39 PM
TMc993
TMc993's Avatar
Default OT: Ever clayed a windshield?
Last week before I clayed my 993 I was reading about clay on the Meguiars site and they mentioned that their clay was good for use on windshields.
I have a pick-up with a new replacement windshield that I can't get completely clean (Some kind of oily haze) and thought I might give it a try.
It makes sense that if the clay won't scratch paint it would be fine on glass but I don't want to get into a cluster f**k.
Anyone ever clayed a windshield?
Old 11-07-2007, 04:44 PM
lucycan
lucycan's Avatar
I have not but you might try some fine steel wool or a good cleaner like Invisible Glass.
Old 11-07-2007, 04:46 PM
RallyJon
Weathergirl
RallyJon's Avatar
I've used glass polish to remove haze. Worked great. I wouldn't use a really abrasive clay, but a mild one should work fine.
Old 11-07-2007, 04:47 PM
Terry Adams
Terry Adams's Avatar
Definitely not the steel wool of any fineness. BTDT.
24FPS
24FPS's Avatar
fwiw: i clay it when i do the cars... does a very nice job, then i clean & occasionally apply the 'rain guard' stuff. nuttin' betta imho.
& yeah... i'd save the steel wool for a troll's *** imho.
Old 11-07-2007, 04:53 PM
lucycan
lucycan's Avatar
Ive used steel wool very successfully to remove hard water spots and other various scum. As long as its fine, it should not be a problem.
Old 11-07-2007, 05:05 PM
24FPS
24FPS's Avatar
fwiw: i use polish for hard water, etc. i don't do metal on smooth car surfaces (wood projects yeah). 2each their own i guess.
Old 11-07-2007, 05:08 PM
993Maineiac
993Maineiac's Avatar
Using clay is very beneficial for windshields. Have no hesitency and just follow the directions. I don't know about oily haze, but for general scratches and little dinks it works fine. I do mine once a year.
Al
Old 11-07-2007, 05:24 PM
The Brewmeister
The Brewmeister's Avatar
I wouldn't use anything but a good glass polish to remove stubborn mineral deposits etc. Griot's
Garage (no affiliation) makes a good one. I'm sure there are others.
Old 11-07-2007, 05:26 PM
c2silver
c2silver's Avatar
Use clay on my DD (S4) with no problems.
Old 11-07-2007, 05:37 PM
JasonF
JasonF's Avatar
I have also used #0000 steel wool to remove old and baked-on water deposits on my car's side glass. Spraying the window with Invisible Glass helps as a cleaner/lubricant. I tried this method on a small area at first, and was pleased with the results.
Old 11-07-2007, 06:10 PM
Derek_C
Derek_C's Avatar
My method: Clay bar then window cleaner then rain-x
HTH,
Derek
Old 11-07-2007, 06:41 PM
ZombiePorsche44
ZombiePorsche44's Avatar
When I clay the car, I clay the windshield too, works great for me........ZP44
Old 11-07-2007, 07:37 PM
H.H.Chinn
H.H.Chinn's Avatar
Save the Clay bar for cleaning the painted surfaces of the car. I like to use Soft Scrub bathroom cleanser for cleaning the glass of the oily film that seems to be prevailent. The mild abrasives are safe and recommended for acrylic bath tubs and the bit of detergent cuts the grease.
Old 11-07-2007, 07:39 PM
mhm993
mhm993's Avatar
+1 Clay +soapy water works fine on glass. Though I like the softscrub idea.
Quick Reply: OT: Ever clayed a windshield?
