Side mirror switch replacement
Anjin San
I think I have to replace the side mirror switch. Both sides will not move up and down but only side to side.
is it as easy as replacing the window switches?
Yep - just carefully pry them out, disconnect the cable, replace and push back into place.
Edit: Oops - I misread your post thinking you meant the window switch. However, I think the mirror switch is a pressure fit as well.
...just be sure to not drop the lead down into the door during the process
