Problem With Bilstein Rear Shock Drop Link
This week I had a Bilstein HD shocks, Porsche lowering springs and M030 sway bars installed on my 993. I drove it about 300 miles today and after returning home, happen to be under it and spotted one of the new rear drop links had popped out of the socket at one end. Any ideas on whether or not this is just a defective part or poor installation? Thanks.
RL Technical Advisor
Installation error, as that swaybar mount moved........
The technician should have installed a locking collar below the upper swaybar mount to keep it from rotating.
maybe just a defective part.....the only thing I know is that the top and bottom of link, where it attachs to the sway and to the shock, the link needs to be completely lined up when the car is off the jacks
Id two are not installed, there is a good chance the drop link mounting bracket, attached to the shock, will rotate. When this happens, the geometry goes critical...the drop link becomes misaligned and will break...sometimes you can even tear up the drop link mounting bracket {See below, for good and bar!}.
After eating numerous 993RS rear drop links...I had the secondary collars installed, added a patch of paint and made a scribe mark. I check to see if the scribe marks indicates a change.
I have also gone to Tarett Engineering drop links. They are extremely well crafted. I bought the front and the rear drop links...they are now up and running with my PSS9 suspension and my TRG sway bars. Tarett Engineering www.tarett.com
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
The Racers Group has the locking collars for the Bilstein shocks. Call and ask for Austin Ford. Austin is a good pal of Viper Bob. L<et him know if they are Bilstein HDs or PSS9s.
The drop links come from Tarett Engineering. Let them know I directed you to them...I get no $ or consideration. I just believe in the company and their products and want them to succeed!
I hope all is well soon for you.
Thanks Martin, will do. I appreciate your help. Hope they ship quickly as I just got my 993 back after a 5 week clutch job. At least it is now in my garage instead of a shop.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
This is something I wish Bilstein would address by simply adding lock collars to the kit. This is a typical occurrance with both the HD and the PSS9 kit. It seems to always happen with the right side, presumably due to thread direction and the plane in which the drop link thrusts with loads from the rear bar.
Now both shocks need to be removed, disassembled, add additional lock collars reinstall and in a perfect world, realign the car, or at least have the rear toe reset.
Sorry to hear of this. What a hassle!!
This is the first I've heard of this locking collar unless I just missed reading about it in the install instructions. More than likely I'm going to try the install myself when I do the upgrade. I'm going back to read the p-car writeup and see if it's mentioned.
But, is the reason for the collar the shocks or the lowering springs? Why doesn't the stock suspension have to use them?
Glad you brought this little issue up Quasr.
I swear I got the locking collars with my HDs from VB. I got it as part of the group buy last year though, not through his eBay sales.
Ive run about 900 miles with PSS9s and so far no movement of the rear drop link mounts that I can detect. I occasionally look and had it inspected recently up on the rack in the shop I had the work done. Same story. Nothing. Hope it stays that way. My understanding is there is only one locking collar and its adding one more on the opposite side of the drop link mount that people are referring to here. I REALLY wish I'd known about adding a second locking collar to each side before having the bilsteins installed. Now I just have to drive around being paranoid about it or drop some serious coin on adding more locking collars and new alignment.
