Used Performance Mufflers
Are they the type that bolt on to the factory mufflers? I might need tips that I can attach to a set of fabspeed mufflers that are currently set up for a c4s widebody application. Do you know if your tips would work for such a retrofit?
I think so. IIRC, the muffler outpipes, not the tips, are shaped differently for a wide versus narrow body. The tips bolt right onto the pipe with no offset change. If I'm wrong, someone correct me.
