Oil Change/Interval Questions
I have changed the oil on my P-Cars once a year regardless of mileage.
I do wonder how leaving oil in the car that has only 1500 miles on it does any real damage. I know it breaks down over time but just curious. What contaminents does the oil pick up from sitting in the container on a shelf in a garage through different heat cycles for a year, 2 years, etc.
Just thinking out loud.
Many complaints about getting the second filter off but once you do it a couple of times it's really not hard (just a little messy). The P-car advice to remove an oil line is definitely incorrect. If you remove the orange boot to the hot air ventilation intake on passenger side it's not too hard to get to. Just need a bottom-mount filter wrench to get it out easy.
Also seen comments about needing a container to catch 11 quarts. Good news - you really only need to catch the six or so quarts from the oil tank, which you can put into a jug, then catch the other four or five from the crank case.
I can't advise on (temporal) longevity of oil since I drive 25K a year. Changing mine every 10K right now.
Dave
Dave
I plan on changing mine yearly.....i STORE IT for the winter, and have been told that you dont want used oil sitting for months cause of the acids, I think.......and then in the spring, she's ready to go!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Do any of you really get that much from the crankcase?
For intervals, since I track the car as often as possible, I typically change it every two track days, both filters, always.
GBX oil every fourth track day or once a year, whichever comes first. And always hope not to see chunks in the GBX oil
TIA
Maybe Chris is right on more coming from the tank - I have been spoiled using my friend's garage which has one of those big 30 gallon catch cans. But I do think I get at least a couple of quarts if not more out of the crank case.
Mine gets changed every 3000 miles or 1 year, which ever comes first. Since I don't put 3000 miles on either Porsche in a year, they both get changed annually regardless of the mileage.
It's like taking vitamins; probably doesn't do a lot of good but you feel like it does.
OK so no one seems to talk about dumping the oil out of the cooler. I disconect the line under the second oil filter, dump the oil out of the cooler, chagne both filters. I do mine once per year, or 5000 WECF.
Actually I get a bit **** at the end, I disconnect both coils and crank for about 20 to 25 seconds to build oil pressure and nut run combustion against the mains.
Yeap its expensive and makes a big mess, I surely do not want to find out how much an engine OH is.
My service advisor at the dealer I have been taking my car to for the last 6 years for oil changes (Pioneer Porsche in San Diego) told me the last time I was in there that Porsche has officially changed the recommended oil change intervals for 993s to every TWO years, or 15,000 miles, whichever comes first.
When a dealer tells me they want to work on my car LESS often I tend to believe it's a legitimate recommendation. Of course, they overfilled the sumab**ch the last time I brought it in so they're not going to get another look at my car again anyway....
Mark
'98 C4 Cab
Mark
'98 C4 Cab
Hmmm, I read somewhere that having the oil in the engine for a bit longer is actually better for the engine. The conclusion of the study is always having fresh oil in the engine is worse than having slightly used oil over the long term. some of the chemistry changes in the oil...but I can't find the reference.
I change mine when it needs it, usually once a year. With the hoist its a snap anyways....
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
Check the archives on the 928 forum for "oil analysis report" by Doug Hillary: there are ~10 such reports - which track the saturation curve of fresh oils ( with various contaminants/wear items) .... and the leveling out of their concentrations early in the verrrry long service life of synthetic oils.
boy its getting cheaper to run my 993! plugs at over 60K,
Oil change at 15-18k
have 102k on "Red Dog", drive 20k/y., still in love with it! not a "hangar Queen"
fwiw, air cooled aircraft engines go to time between overhauls[tbo] more often if not stored and runoften, but most cylinders are not chromed. having flown for over 20yrs im told the cheapest thing you can do for your engine is run it. i see no substative diff. with the Pcar.
i dont think i abuse it, but i run it hard when the temp is off the peg.
hope ive not hijacked.
thanks
ds
thanks
ds
