Alternator and Engine Hareness Fried- Ideas?
I have a 97' 993 2S. This all started when I brought the car in for some body work on the drivers door and left fender. When I went to pick up the car, the shop told me it was at the dealer getting the ABS light reset......Hmmm.
After many questions and finding a blown fuse behind the radio, they finally admitted to having to jump start the car because the front hood was left open (story still in question). So 1 month later I was driving and the ABS and battery light comes on...low voltage. We checked the voltage at the battery, 12.2 with the car off, 11.8 with it running. Bad alternator... I bring down to the dealership and when they pull the alternator out of the fan shroud, the main wire is melted. We currently have a wire harnees on order from Germany and I am out 3K and my car for a month.
I have had zero issues with this car for the 3 years I have owned it.
Has anyone lese seen this issue. This is not one of the VIN's under the recall. The battery does not appear to be cooked. We haven't pulled the harness out yet, so we don't know where the short is (starter maybe, something near the parts being worked on?). All other wiring seems to be OK (ie, ignition, battery to starter). The car would start fine.
Any help is appreciated. Thanks
Joe,
Thanks for the response, I talked to the manager of the body shop and we really can't prove someone hooked the cables up backwards. If this was the case, though, wouldn't they have fried the ECM? Why would the wire from the alternator to the starter melt the insulation?
I have several theories, 1 being that they hooked up the cables and it fried the regulator, then my alternator started putting out 18V and cooked the wire. The battery did not boil over, though.
It sounds more like a short on that wire or in the starter. We haven't pulled the harness out yet or checked continuity on these items, but I was wondering if anyone else had a similar issue.
Thanks again
Thanks again
Hi! Bad luck, if it's a wrong connection have a look here :https://rennlist.com/forums/showthre...=fried+harness
Cheers
JP
Cheers
JP
Two questions:
Was the harness changed under the factory recall?
Did the shop follow the directions to jump start outlined in your owner's manual? (Let THEM tell you about the specific procedure they used rather than tip your hand about following the owner's manual.)
Joe,
I read through this post...https://rennlist.com/forums/showthre...=fried+harness
Very interesting.
I have been working with the manager of the body shop and they are helping me with the bill, which is very much appreciated. The dealership has also been very helpful in discounting parts and working with me.
Unfortunately this is a VIN not covered under the recall. The harness shipped from Germany in 4 days, which must be a record. I should have the car back early next week.
Thanks again for everyones input.
Very interesting.
