993 Forum 1995-1998
What weight oil do you guys run in your 993? (with hydraulic cams that is)
Old 10-15-2007, 02:41 PM
ste993
ste993's Avatar
Mobil 1 0w40
Old 10-15-2007, 03:37 PM
007DT
007DT's Avatar
15W-50 Mobil 1
You can by it at Costco by the case here in Atlanta (No Affil) Just bought 2 today.
Old 10-15-2007, 03:44 PM
ppashley
ppashley's Avatar
i just ordered 2 quarts of Mobil 1 15-50 from Auto Barn.... they deliver!
Old 10-15-2007, 03:56 PM
Dan V
Dan V's Avatar
15W-50 Mobil 1 w/Gold cap. Next time I'll get the 'regular' Mobil 1 since I change it every 5K and therefore "EP" is superfluous.
Old 10-15-2007, 04:56 PM
FLYT993
FLYT993's Avatar
M1 5W-50 and/or Castrol Syntec 5W-50.
Old 10-15-2007, 07:30 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Mobil 1 15W-50, but I really want to use something else. Thinking of Redline. Using Mobil 1 V Twin Motorcycle 10W-40 oil in the Sequoia and Miata and might start using the 20W-50 in the 993.
http://www.eliteetc.com/momooil.html
Old 10-15-2007, 07:57 PM
CDILL
CDILL's Avatar
Mobil 1 0w-40
Old 10-15-2007, 08:24 PM
bv shady
bv shady's Avatar
ROYAL PURPLE 20-50
Old 10-15-2007, 09:01 PM
FLYT993
FLYT993's Avatar
Originally Posted by Charles Navarro
Quick question. What weight oil do you guys run in your 993 if you still have the hydraulic cams, rather than a solid setup? What I am getting at, is that I have a lot of people who own both 993s and earlier cars, and would like to use just one oil, say Swepco 306 15w40 or Brad Penn 20w50. If M1 15w50 had been working for you guys, then the other two products more than likely won't have any problem residing in a hydraulic 993.
Charles, hopefully a simple question. If what I have read is accurate, and 90%+ of engine wear occurs on start up?, then doesn't it make sense to have a lighter weight oil to "ostensibly" circulate the oil through the engine quicker? Or are the differences between the grades for what I will call time-to-lube..TTL (how long it takes oil to circulate through a dry engine") negligible? E.g., no significant difference between TTL for a 0W and
5W, or a 10W and 15W, but maybe significant diff. between a 0W/5W and a
15W/20W? Just wondering if anyone has thought about this or done any real analytical research?
Old 10-15-2007, 10:47 PM
Pete Lech
Lifetime Member
Pete Lech's Avatar
Motul 300V 15-50
Old 10-15-2007, 11:39 PM
e9stibi
e9stibi's Avatar
Mobil 1 0w40
Old 10-16-2007, 12:49 AM
Jay993turbo
Jay993turbo's Avatar
Originally Posted by RallyJon
Need to caveat that with climate and conditions.
If I drove in warm weather only, and for long drives, I might use a 15W50. As an almost daily driver throughout the winter with frequent cold starts, I can't imagine using anything other than 0-5W40
I agree. I use torco 5w-50.
Old 10-16-2007, 11:22 AM
Charles Navarro
Charles Navarro's Avatar
Received 1,142 Likes on 597 Posts
Yes and no. I'll just leave it at only that Brad Penn and Swepco say their 20w50 (10% syn) and 15w40 respectively are safe for cold start up protection down to 20F. That said, I personally limit my use of 20w50 Brad Penn (or any other synthetic or semi-syn 20w50 for that matter) for cold starts down to 32F and usually my garage in the winter is closer to mid 40s or 50s.
Old 10-16-2007, 11:49 AM
RallyJon
Weathergirl
RallyJon's Avatar
That's a good point--if ever there was an argument for running two different oils, the 993 is it. In the Summer, oil temps can hit 248° mark (on the gauge--who knows how high in, say, the cylinder head). Certainly reason enough to run high quality synthetic of adequate high-temp viscosity. In the Winter, I can go weeks without getting it over the 194° mark, even driving pretty hard.
I could probably run 0W30 in the Winter and the total wear would be less.
Old 10-16-2007, 11:50 AM
melman911
melman911's Avatar
Mobil 1 15W50
+1
Quick Reply: What weight oil do you guys run in your 993? (with hydraulic cams that is)
