YOU CAN remap 96 ECU (extra 22HP)
Anyone here of tech 9 tuning. There is a guy in toronto that apearantly does this remaping for 993s. His catalogue shows that he can do a 1996 for $1100.
you end up with an extyra 22HP and 23 PFT.
any experisnce with this guy or tech 9?
Did I discover something new or were we always able to remap a 96?
Hmmmmm ... interesting. I've got a '96 993 cab ... but thought this was tough to 'get done'. The only one I ever knew of possibly being able to something was Steve Weiner at Rennsport here in the States. I have not heard of this operation. Anyone else?
Scott
Scott
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
why does www.awe-tuning.com have prices for 96?
giac chip
1996 - 1998 Coupe 4WD 6 speed manual 9698_993_DME_376.649 $995.00
giac chip
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I am as well. Ive always been told you have to replace the entire ECU from a '97 or '98 at a cost near
2gs and that piggy back systems were bogus and unreliable.
Agree with David....22hp ?? Doubt it.
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
In Cali, the best pump gas we can buy is 91 octane. Some of the chips, or so I have heard, like the octane to be significantly higher...the knock sensors could go nuts under certain situations...retard the spark, and the power gains disappear.
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
RL Technical Advisor
Some musings,.....
The '96 cars use non-reflashable twin chipsets that are not available anymore. There IS a piggyback circuit board made by EVC that accepts a re-flashable chip (soldered-in) that gets attached to the main CB, but IMHO, they are not very reliable when we tested them in '98. I've redone 3 cars so equipped that item just in the past year. The '97 .376 ECU and the '98 .649 ECU's can be done; the '96 .008 ECU's cannot.
22HP from anyone's chip seems truly optimistic, even if specifically tuned for race gas. I have some experience in that regard,...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Aggressive efforts with ignition timing without the fuel octanes to support such tuning only results in knock-sensor activity to pull back the timing and a net LOSS of performance. In some cases, uncontrolled detonation occurs that damages engine components.
Final thought,....Caveat Emptor on such things,...
