Anyone just replaced a torn boot? If so where did you get it? I'm only finding the entire stabilizer, and the price for the M030 suspension part is twice the standard part.
There is a place that provides 356 replacement rubber boots...I used them once on my SC to replace a torn boot. It worked like a hot damn. Unfortunately that is all I know, I have lost there reference. You might want to post on the 356 or Pelican boards.
I didn't find boots that were an exact fit so it looks like I'll eventually have to replace the entire link. However, I think I substantially increased the life of the existing joint by repacking it with Lubri Moly grease, rotating the torn portion to the top, then adding the new boot over the existing one. It was fairly fixed in place without anything else but I added a tie wrap just for good measure.
Rather than remove the bolt, I instead just split the new boot and fitted it around the old one. With the two splits offset, it should keep out the dirt and water until I replace the entire link; and the new boot color matches the calipers.
I've seen cars go with torn boots for quite some time so this repair may end up being all I need for a while.
