993 Forum 1995-1998
cruise control not working: suggestions?
Old Aug 28, 2007 | 10:14 PM
Lorenfb's Avatar
Lorenfb
"I am willing to bet money that the original servo failed because of a cold solder."
There's nothing really in there but; a motor, a solenoid, & a feedback pot.
Hardly your typical unit with potential for cold solder joints.
Old Aug 29, 2007 | 10:22 AM
Robin 993DX's Avatar
Robin 993DX
Lifetime Member
Loren,
Both units that I repaired had cold solder joint at the through hole soldering on the PCB. Exact same issue with a cab top controller repair I did not too long ago.
Please understand that I am not trying to start a auto electronic repair business, I have no interests. I did all the repairs for free, just helping out another Rennlister.
Old Aug 29, 2007 | 12:31 PM
Lorenfb's Avatar
Lorenfb
"Both units that I repaired had cold solder joint at the through hole soldering on the PCB."
The point is to not mislead Rennlist members into thinking that the actuator is a high falure rate type of unit.
The cruise ECU itself has a higher failure rate which is still very low overall.
That actuator is not only used by Porsche but also by Mercedes Benz, i.e. last 25 years, which basically never fails too.
Old Aug 29, 2007 | 12:34 PM
Marlon's Avatar
Marlon
Any simple way to 'test' these components on a 95' 993?
Old May 21, 2012 | 12:23 AM
JPS's Avatar
JPS
DId anyone find that DIY?
Old Jun 18, 2012 | 02:36 AM
asofine's Avatar
asofine
Beuller? Mine crapped out today.
Old Jan 26, 2015 | 06:38 AM
Malibu101's Avatar
Malibu101
Old Jan 26, 2015 | 11:42 AM
Allen's Avatar
Allen
I have had cruise control fail on many cars...it has always tuned out to be a switch. There is a switch that indicates the brake in pushed, and a switch that indicates the clutch is pushed...check those...I bet one of them is sticking. I don't know exactly where they are on a 993...but in my experience, they have been actuated by the brake or clutch pedal...so look at the bottom of each those pedals for a switch...if it's very quite...you can probably even hear it actuate.
Old Jan 26, 2015 | 11:53 AM
PRSWILL's Avatar
PRSWILL
Went through this last summer. Ended up being the control module under the passenger's seat. I got a replacement from an R lister for $ 100 bucks- plugged it in and works perfectly. These modules ARE known to fail. Why? who knows. The good news is this module ONLY controls the cruise so while there's no other systems effected, it can be difficult to diagnose. I'd try the switch first as recommended, but this may be your culprit.
