993 Forum 1995-1998
Looking for input of where to mount the V1 remote display
Old 08-19-2007, 12:46 AM
RallyJon
Weathergirl
RallyJon's Avatar
If you can look up at the V1 mirror, you can look up at the V1 itself and save the cost and wiring of the remote display entirely.
Old 08-19-2007, 05:06 AM
David in LA
David in LA's Avatar
I have mine in the ashtray which IMHO is good as far as a stealth appearance but is not the best location since the display is not in the line of sight. The biggest issue really is where to put the main V-1 unit...especially in a cab...I've seen other cars (BMWs, Audis) that have used a dummy box or the rear shelf or below the third brake light...still waiting for someone to come out with a good mod
IMHO Robin's idea to place the remote display in the tach is the best location (if you don't have OBC) but I would perhaps modify it with plain or dark plexi over the display so that it is completely dark w/the motor off. The pic below would also be a clean install if there was a suitably flat mounting surface above the steering wheel.
Quick Reply: Looking for input of where to mount the V1 remote display
