993 Forum 1995-1998
Concensus on Trans Lube??
Old Jul 25, 2007 | 03:58 PM
jaholmes's Avatar
jaholmes
Originally Posted by ppressle
I recently installed Devlac and had some problems on the track. 2nd to 3rd shift was not happy unless the shift was quite deliberate. Box has been perfect up until now...
No idea what lube was in there before, but I will be changing it before I go out again.
I had the exact same problem with Delvac. I took it to the dealer and they put in 80W90 and it's back to normal. Verified on the track.
Old Jul 25, 2007 | 04:03 PM
Marlon's Avatar
Marlon
sounds like dino is a good way to go...
Old Jul 25, 2007 | 08:21 PM
Wilder's Avatar
Wilder
Jim (holmes), sorry to hear about your troubles.
When I researched tranny oil, I primarily looked for posts on the Racing and DE forum and as per Bill's comments, I found that nearly everyone uses Delvac on Cup, RS, RSR and track cars. My box is regeared and the shop that built it recommended Delvac too. I just changed the fluid in my other C4S to Swepco 201 and that works well for street.
Jimbo: I had that same crunch going from first to second on my C2 cab. I don't know what fluid was in the box when I bought it but I changed to Swepco 201 and it improved some, FYI.
Old Jul 25, 2007 | 09:12 PM
ppressle's Avatar
ppressle
Thanks Jim. Glad to hear that at least one other has had the same issue. I certainly hope that is the issue and it is not something inside the box!
I'll try some Redline 75-90 gl5 that I already have. If that doesn't fix it, I'll go down to the dealership and beg for some of their oil...
Lets hope for the best...
Pete
Old Jul 26, 2007 | 12:44 AM
milrad's Avatar
milrad
PS Armorer
Originally Posted by TroyN
Tried Swepco and got crunchy so immediately switched back to Mobil 1, and all was good again.
I did exactly the opposite, with the same results. Couldn't get the Mobil 1 out fast enough. I am one who swears by Swepco 201, but as others have pointed out, you need to find what works in YOUR car.
