993 Forum 1995-1998
Got hit by the DME...
Old 07-24-2007, 03:31 PM
texas911
texas911's Avatar
Default Got hit by the DME...
Finally. Been waiting for it and was prepared. Had my spare DME relay in the trunk already. Its amazing how much taller the new one is compared to the old one. Hopefully it will last a while.
Just a friendly reminder to always keep a spare one in the trunk.
Old 07-24-2007, 03:39 PM
jimq
Burgled
jimq's Avatar
mine were the same size !
Old 07-24-2007, 03:49 PM
InTheAir
InTheAir's Avatar
So were mine.
But, nonetheless, newbies (not you guys ), get an extra DME Relay to keep in the car. Because when your DME Relay fails, the car will not run. It is a simple replacement in the fusebox and you're on your way.....assuming you have a spare. Otherwise, you're probably lookin for the tow truck and a FEDEX box from Pelican.
Old 07-24-2007, 04:02 PM
Rick Lee
Rick Lee's Avatar
One day I was in the 993 and came across a broken down, gorgeous '88 Carrera cab on the right shoulder. So I stopped to help. Poor guy's wife was not looking amused. I poked around a bit and said he should first try a new DME relay and "You do keep a spare one of those, don't you?" He said, "No, but I've heard I should." And then he told me he had just spent $12k on a full engine rebuild (WTF?) for that car. Unfortunately, 993 DME's don't work in 3.2 Carreras. So he had to call a tow truck. I thought his wife was gonna ask me to take her home.
Old 07-24-2007, 04:04 PM
TwinDaddy
TwinDaddy's Avatar
Originally Posted by InTheAir
...get an extra DME Relay to keep in the car.
Thanks for the info! I am a relative newbie, so I was not aware of this problem. Looking at Pelican, I see a "Fuel Pump DME Relay," part no. 993-615-227-00-M76. I assume that's the one?
Old 07-24-2007, 04:17 PM
Rick Lee
Rick Lee's Avatar
Should be the right one. These are only around $25 at the stealer too, so shipping from an online source may eat up your savings.
Old 07-24-2007, 04:19 PM
InTheAir
InTheAir's Avatar
Yup, that's the one: 993.615.227.00
Here is more info on the "condition": http://p-car.com/diy/relay/
Old 07-24-2007, 04:22 PM
bill d cat
Feral Cat
bill d cat's Avatar
Without a doubt a spare relay is the way to go -- but if you're really, really, really stuck and the wolves are circling the car -- is there a reason why you can't bridge the relay contacts with a paper clip?
Old 07-24-2007, 04:29 PM
Black993
Black993's Avatar
hmmm, and I just placed an order with Pelican today...should have thrown one of these in dang it!
Old 07-24-2007, 04:34 PM
jimq
Burgled
jimq's Avatar
I got mine at a regular car parts place in town and was cheaper then online even with tax. They just ordered it from the local parts warehouse and i picked it up the same day.
Old 07-24-2007, 04:37 PM
air eater
air eater's Avatar
The worst case scenerio would be: 100 or more very rural miles with no cell service from home.
I just ordered one DME from Pelican. They have 65 units in stock.
Thanks for the very helpful tip!
Old 07-24-2007, 04:39 PM
Garth S
Garth S's Avatar
You can .... but it helps to have a couple - or a 3 branched wire jumper made up. When the relay is closed, +12v flows from #30 to both #'s 87 & 87b - so bridge the three of these with the key off, and start. Remenber to remove it when shutdown, as it will keep the pump energized.
The simple way to remember is to look at the diagram on the side of any relay .... take live +12v from #30 and feed it to whatever pins are made when the indicated contacts are closed. This is practically always #87 on a standard 4 pin relay.
Old 07-24-2007, 04:42 PM
TwinDaddy
TwinDaddy's Avatar
Perfect. Thank you!!
Old 07-24-2007, 04:46 PM
Black993
Black993's Avatar
any specific place? I see we're kind of close and would love to have this out of the way. Was it just like a pep-boy's type place?
Old 07-24-2007, 05:36 PM
texas911
texas911's Avatar
Also don't worry about DYI, the relay can only go in one way.
Quick Reply: Got hit by the DME...
