993 Forum 1995-1998
running rich after o2 sensor replaced?
Old 07-22-2007 | 09:49 AM
mbb993's Avatar
mbb993
Default running rich after o2 sensor replaced?
I was having a intermittant CEL 1224 so replaced the o2 sensor. No more CEL but smells like it's running too rich. Otherwise running fine but havn't driven much yet since replacement.
In MY 95 (OBDI) is there an ECU reset be done or do I need to go through any rediness code reset procedure like on the OBDII cars?
Thanks!
Old 07-22-2007 | 12:14 PM
Black993's Avatar
Black993
Bump for Mark!
I need to keep an eye on this one too. I'm getting the same CEL code but have not replaced it just yet.
Old 07-23-2007 | 11:04 AM
mbb993's Avatar
mbb993
bump and update.
Did some driving around over weekend and it seems that the fumes may be lessening. Perhaps ECU reseting fuel mixture? Still would like to know how the system is designed to work in this situation.
Old 07-23-2007 | 11:21 AM
John H's Avatar
John H
When the O2 goes bad it defaults to running rich IIRC. It will take some driving but it will reset.
Old 07-23-2007 | 01:26 PM
Dave Crellin's Avatar
Dave Crellin
I had a similar problem a couple of years ago, and the car failed it's California smorg test. turned out that there was an injector that was mislabeled - ie the box said the right part # and the part showed a different part#.
Maybe worth checking
Old 07-23-2007 | 04:18 PM
Rick Lee's Avatar
Rick Lee
I had the opposite experience. I had an O2 sensor start to go out and the CEL code I got was lean condition in the right bank. I've since replaced all four O2 sensors and the CEL has not come back on after about 280 miles.
Old 07-23-2007 | 04:37 PM
John H's Avatar
John H
Rick,
I think we are saying the same thing. When the O2 sensor goes or starts to go, it often gives false lean codes. The ECU tries to compensate by running richer (even though it is probably not running too lean). Thus the car running too rich until the ECU catches up following an O2 sensor replacement.
Old 07-24-2007 | 03:42 AM
Peter R.'s Avatar
Peter R.
Tell me about it. Mine belched out pure 98 octane when the sensor went. Left the battery unhooked for 24 hours after I'd replaced it, and it took about 100 miles before things returned to normal.
Peter R.
