996 shift knobs to 993?
I'd like to know this to, but I think you swap out the shape ring under the leather that forms the shift chamber in whatever car it comes out of. Then you re-staple it using the 993 shape ring.......guessing
Couple ways to do it. You need to cut off the boot from the 996/boxster since it won't fit. So you have to butt up the new **** to your old boot. Here, you can use zip ties or stitch them together. I stitched mine together since I didn't like the zip tie solution. Wire would probably work a LOT better than zip ties.
![](http://home.comcast.net/~dirtybeigecamry/images/Interior11.jpg)
This thread shows the **** presently after Rob Budd at 928 Leather Shop recovered it:
https://rennlist.com/forums/993-forum/331934-pics-of-interior-transformation-leather-dash-etc.html
I did this years ago on my 964. I used a 996 wood ****. It was originally attached with zip ties from the factory. I cut my old **** and reused the shift boot, very easy.
Originally Posted by md11plt
Gert has them already modified.
There was recently a Central Florida members, 95cabinfl if I remember his user name, that put in a 997 shifter. You make do a search for that. It looks great and is certainly on my "to do" list
Thanks Black993. I did the mod using a 997 shifter I picked up on Ebay. Do a search on my name and you will find the mods with pics.
If I can do it, anyone can![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Ron
Ron
Ron
Ron
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Wasn't even CLOSE on the user name! sorry about that Ron....lol
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
I did this mod awhile back too. Took both the 996 shifter and my 993 shifter / boot to a local upholstery shop. For $10 he took the 996 shifter and glued it to my 993 boot. Looks absolutely perfect, and never been a problem.
Originally Posted by atan888
besides the boot dont we have to change the adaptor inside the ****?
In my case, the **** was an eBay find, sans boot. I cut the boot off my old shifter, then zip tied to the shift lever, then installed the ****. Looks factory, no issues with rattling, etc.
-Chris
