993 Forum 1995-1998
LPPM versus RSR mods?!?!?
Old 07-18-2007, 05:43 PM
  #31
Caveman
Caveman's Avatar
That welding doesn't look very good quality on the "Motorsound" silencer...
Old 07-18-2007, 08:01 PM
  #32
993_Pilot
993_Pilot's Avatar
It isn't very good quality on the normal cans either. It was obviously done with a high speed (mig /wire-feed) production type welder.
Old 07-19-2007, 03:34 AM
  #33
long_beach_968
long_beach_968's Avatar
Well let me tell you, they did not skip out on the quality of the cans, that heavy stainless took me an hour and a half to cut open both mufflers.... and for like 2 lbs of steel wool.... so not worth the effort. This had better sound amazing.
Old 07-19-2007, 12:11 PM
  #34
993C4Smontreal
993C4Smontreal's Avatar
btw...my rsrs's have a little poping.....
Old 07-19-2007, 12:27 PM
  #35
TheOtherEric
TheOtherEric's Avatar
So if the steel wool is only 2 lbs, I wonder where Robin finds the other 13 lbs to remove!!
Old 07-19-2007, 12:32 PM
  #36
993_Pilot
993_Pilot's Avatar
What the heck did you use to cut them open? I cut mine open in about 5 minutes each with a cutoff wheel on a 4-1/2" angle grinder. If all you are doing is removing the packing, you may be a bit disappointed. I did a bit more, and it helped, but ultimately I wanted more sound. SEE HERE
Eventually I attempted to do the internal version of the LPMM, but I burned through in a few places due to my lousy welding skills. Now I have completely gutted mufflers. This obviously wasn't my original intention, but they actually sound really good without being obnoxiously loud. The downside is that they do have a little bit of resonance around 3k rpm. They also have a slight burble with engine braking/deceleration which I kind of like. I may try the LPMM on my first set modified mufflers (in the link above) next.
Old 07-19-2007, 01:04 PM
  #37
long_beach_968
I used a cutoff wheel on a 3" angle grinder, took foerver because my cans were 2 layers thick.
Old 07-19-2007, 01:35 PM
  #38
FisterD
FisterD's Avatar
You cut them too close to the top. That is where the end cap and side can overlap ( you know that now). If you just remove the packing material, and that is all, you WILL be disappointed. Not hardly any change at all.
Old 07-19-2007, 01:39 PM
  #39
Cactus
Noodle Jr.
Cactus's Avatar
So does anyone have LPPM'd RSR's? If so I want to hear that sound clip.
Quick Reply: LPPM versus RSR mods?!?!?
