I INSTALLED THE PURPLE H & R SPRINGS YESTERDAY/ SATURDAY
HI GUYS
I got the purple springs in friday..
the mail man had it for 3 days in his truck..before delivery
all installed saturday/see pictures
one glitch....on the drivers side....the lower control with the shock orboser bolt..
I used the T40. along with box 18MM wrench.....
the T40 BUST OPEN the tip of the BOLT / ...what should I DO NOW about this
lower control arm shock orboser bolt...could this be removed & replaced ..or..
could I replace this BOLT ...or ..do I have to get a new lower control arm
everything is back in place ...but I need to fix it immediately
CROME (954) 551-8168..call with suggestions
FT.LAUDERDALE FLORIDA
BEFORE PERMANENT PLATES/GLITCH WITH SHOCK OBSORBER BOLT TIP/T40
HI GUY
i order the rear bridge wing spoiler from MA SHAW.../....PAINT & INSTALLED
change all 12 plugs
remove & replace purple springs
remove & replace 3 fan belts/replace 3 stainless steel bolts with hex heads
drop the complete exhaust system & replace all stainless steel nuts
remove all old brake pads replace all new pads around
thinking about headers
what else could I do..to this car...I like the standard wheels
CROME
change all 12 plugs
CROME
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Otherwise, the list is wide open
FLORIDA HEAT / HEADERS WOULD COOL DOWN FASTER
HI
I wanted to remove my standard (GILLETTE) heat shield exhaust system
cut out all that stainless heat shield surrounding the exhaust
........run with this in hot florida sun ....it will cool down faster
get a extra standard (GILLETTE) pair for replacement before
going up north in the cold weather
so i am looking to buy a pair of ( GILLETTE ) heat shield right now
anyone has this for sale/1996/C4
Originally Posted by chris walrod
RS splitters up front would look nice. I dont feel there is too much to be gained with headers.
HI GUYS.
Good Luck
Great to see someone go after it...
You will love the 993.....
I see the 993 Aerokit 1 on your tail. As Chris mentions, to balance the car you should consider the Aerokit 1 front splitters. I recently acquired an Aerokit 1 tail have it installed. In the front of the car, I have 993RS splitters...they are staying....The are some trick spoilers available for the front end; I just bought a set from Gert at www.carnewal.com The splitters come as a set:
One (1) of the 993.505.525.01 (Goes across the front in place of the front protection bar.
One (1) of the 993.505.526.01 (Appears to go on the drivers side)*
One (1) of the 993.505.523.01 (Appears to go on the passenger side)*
I will bolt these up to counter any downforce produced by the Aerokit 1 rear spoiler. Very trick parts...never knew they existed until about a month ago.
*Assuming a US car with the driver on the left side.
Car looks sweeeeet! I always like the look of the red ones even though clearly it goes without saying, the black ones go faster than all the other colors.
Is that the car that was advertised forever and had something in the description about being a PCA member's car?
THIS IS NOT THE PORSCHE/PICK UP CAR FROM BALTIMORE JUNE/ 21/07
HI
I bought it from baltimore md...drove it back to ft.laud..1000 miles
car had 57,000 miles..still smell's new
this guy need the money to put down on a house immediately cant wait $25 G"s
nice deal.....every excellent..
CROME
I will look into aero kit.....see if i like
CROME
I've had both the RS splitters which pretty much bullet proof. The GT3 three piece front spoiler is also a factory part if you can still find it. Nice looking but a bit more difficult if your lowered on the street.
