intake systems
Originally Posted by Pan58
Jeff that is my plan at this point is to buy a used lid and modify it like the cup car design and see how it goes, plus either a K&N (lightly oiled)...
Originally Posted by TargaTango
Mark, Exactly what I thought when I read this thread but I am not sure it is that simple. Check out this thread which I am wading through:
https://rennlist.com/forums/showthre...ferrerid=26865
All the best,
All the best,
Technical Guru
Originally Posted by Ed Burdell
Didn't someone here say that the oil from the air filter would eventually make the mass air sensor fail?
MY99-01 MAF air path
![](https://members.rennlist.com/jandreas/Bosch-HFM5-Sensing-Element.jpg)
MY02 MAF air path
![](https://members.rennlist.com/jandreas/996-MY02-MAF-PATH.jpg)
Originally Posted by DJF1
Not so with the 993 air cooled engine. Over the years there have been many that tried, ALL unsuccessful. K&N cone filters literally fell apart when installed in the 993 engine bay a few years back...
A 911 engine is not your typical detroit iron. The air flow in conjunction with the stock ECU is optimized already. What any aircooled engine needs is cooler air. Both systems that you linked will draw hot air in abundance and you will loose power. The most effective add on, if you have an RS tail or any other fixed tail, is the RS snorkel, a $10 part that connects to the end of the stock airbox and draws fresh air from below the wing.
If you want more power you need more dollars than a cone filter....
+1. (Actually, +100). If you're looking for HP, modifying a 993 intake will gain zero. OEM filter works best and the MS airbox cover will give you a little nicer sound. Maybe look into a chip and different cats as the lowest cost mod for addtl 10 HP. Or, save your money and put it into a LWF.
Originally Posted by jimbo3
+1. (Actually, +100). If you're looking for HP, modifying a 993 intake will gain zero. ...
