993 Forum 1995-1998
ABD/LSD
Old Jun 17, 2007 | 01:39 PM
Pan58's Avatar
Pan58
Default ABD/LSD
Okay the 1996 993 that I am in the process of purchasing has a Automatic Braking Differental / Limited Slip Differental. I have checked my books I have on the 993 and it does not really explain what the Automatic Braking Differental Does. Can some one explain this Feature?
Old Jun 17, 2007 | 04:53 PM
ed devinney's Avatar
ed devinney
ABD is a low-speed traction control that selectively applies individual rear brakes to minimize wheelspin. I haven't found it to be terribly useful but the upside is that you get 4 channel ABS as a byproduct.
Old Jun 17, 2007 | 11:30 PM
Pan58's Avatar
Pan58
thanks for the explaination
Old Jun 18, 2007 | 01:24 AM
ZombiePorsche44's Avatar
ZombiePorsche44
"The Bosche 5 ABS/ABD system provides an anti-blocking (ABS) function as well as rear wheel traction control.
The ABD (Automatic Brake Differential) complements the ABS system and is used as a traction control aid at speeds up to 72kph (45mph).
For this purpose, an active input into the brake system is made if one driven wheel starts to spin. Since ABD control has to trigger the driven wheels individually the ABS/ABD system is designed as a 4 channel system."
Quote from Porsche 993, The Essential Companion (King of Porsche) by Adrian Streather
ZP44
Old Jun 18, 2007 | 10:51 AM
RallyJon's Avatar
RallyJon
Weathergirl
It is very useful when starting off in slippery conditions. Especially uphill or turning from a stop. And mine is a C4, so I imagine it would be even more helpful on a C2 in those conditions.
Old Jun 18, 2007 | 01:11 PM
Paul902's Avatar
Paul902
RallyJon,
do you see the green ABD dash light coming on? I've never seen mine coming on during normal driving, although I have seen in a few times doing "abnormal" things.
Paul
Old Jun 18, 2007 | 01:16 PM
RallyJon's Avatar
RallyJon
Weathergirl
Not sure about the light--I'm usually looking at the road in those situations. Most obvious is the clicking whine from the corner that's slipping as the ABS cycles the caliper.
Old Jun 18, 2007 | 08:40 PM
Pan58's Avatar
Pan58
You guys are great , this is my first Porsche , being and aerospace engineer I am kind **** about spec's and details and you folks have come thru in flying colors A+ is given for the help and response to this new owner. thanks alot.
Old Jun 18, 2007 | 08:54 PM
TomF's Avatar
TomF
I actually is pretty cool technology, however primitive by todays standards. I drive my car in the snow once in a while for fun and it is interesting to see when the ABD engages. It only does it occasionally in the regular Seattle rain. I also think that it senses throttle position because when I get the car to "drift" with a lot of throttle, it doesn't engage as long as the revs are up.
Old Jun 18, 2007 | 09:11 PM
Pan58's Avatar
Pan58
Tom you are in the Seattle area , well I am located down by Puyallup go figure
Old Jun 18, 2007 | 09:55 PM
ed devinney
If that's the case you really need Adrian Streather's 993 book: http://www.amazon.com/Porsche-993-Es...2214544&sr=8-1
Old Jun 18, 2007 | 10:02 PM
Pan58's Avatar
Pan58
I have that book and have read it cover to cover twice very good book I might add.
