My 97 Cab is at the shop for a 90K maintenance, a LWF and clutch, a SSK and a few other minor items. I have been having a CEL due to SAI every 500 miles or so for the last couple of thousand miles so I ask them to change out the check valve and have a look-see at the SAI ports when they have the engine/trans out. Sure enough the old SAI check valve is rusted and such, but the SAI ports look clear as best as the mechanic could see, but here is where things get a little interesting. The "distribution body" that the SAI check valve mounts on has several tubes running to the manifold etc and has two steel caps that apparently cover machining holes from the production process. Well the bottom line is that these steel caps (the distribution body is aluminum I think) have small holes due to rust in them and APPEAR to be the cause of the CEL. Has anybody ever seen/heard of this??? My mechanic had never seen it before. Perhaps Steve W. could offer his take on this situation. No I don't have pictures because this happened while I was out of town and the mechanic did not have a camera.
Obviously any moisture in the air from the pump settles into the manifold (since the tubes exit upward), the manifold acts like a water trap, and rusts the plugs. I replaced the plugs.
Big-BRO - thanks for the info - I missed that thread in my search. I still wonder what happens to the system when those plugs develop holes due to rust. Is it a vacuum leak? Does it cause CEL? The mystery continues!
Any chance the codes were P0410 and/or P0411?
I picked up a 0410 code recently ... low air flow on the left bank: think I will check the SAI manifold plugs .... thanks to this thread
Great post Ralph. That makes sense. When the pump runs, air never gets downstream due to the air leak.
The SAI passages could be perfectly clean, but since air never reaches its destination, the system assumes that the passages are clogged and thus the CEL.
Another thing to check before forking out $5K in repairs.
Just a thought, but couldn't these plugs be duplicated in stainless steel or something to prevent the problem from happening again? I don't think there would be any issues with a SS plug threaded into an AL hole (I could be wrong). And given today's CNC use and availability, I am sure someone could commission a run on them and sell them....
KKim - the error codes were the dreaded P0410 every time. I did ask my mechanic about the use of SS for the plugs and he said maybe, but the best thing is to change the SAI check valve every few years.
