95 993 Brake Master Cylinder
I've got a failing master cylinder and porsche wants $700 just for the part. Does anyone have any experience using the Lucas part from Pelican Parts - good - bad - doesn't matter? Any feedback would be appreciated - at the very least by my wallet
Try here: $242
http://www.autohausaz.com/search/pro...er=99335591000
Had to replace mine a while back... been fine since and the old factory one I took off was made by the same company (Lucas/TRW).
Getting the plastic plugged feed lines out the old cylinder was a Friggin Bi@tch of a job (working upside down and laying on your back). There's probably a special tool, but I used an upholstery removal (split Y) tool to pry up the lines out the cylinder.
Thanks for suggestions. I live in Phoenix AZ so I'll just drive down to autohaus and pick up one. Are there any DIYs for installing this out there? Pelican has one for '83 911SC which I suspect is a little different than my 993 ;-)
I just did a master brake cylinder on a C4S...it was a piece of cake. I am not sure why you would be upside down...that cylinder is in the front trunk and its upright? The plastic feed pipes are a bit tight but I gave them a yang while twisting and they came out....I think I might have just been lucky.
Cheers,
Mike
Cheers,
Mike
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Cheers,
Mike
Cheers,
Mike
Either way, those fill tubes can be tough to get off.
Originally Posted by chris walrod
IIRC, the C4S and TT's master is mounted differently due to the hydroboost setup.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by grmnxtc
Chris... that's an understatement if ever there was ! I had visions of never getting the things out and then spending even more money on new feed pipes... tunred out OK after some colorful language though...
