993 Forum 1995-1998
993 twin dists I + II, & spark plug pattern.
Old Jun 6, 2007 | 04:53 AM
JM993's Avatar
JM993
Originally Posted by JasonAndreas
You want to torque them to 30 Nm (22 ft-lbs).
Note that the esteemed Mr. Andreas used the word "want." Good luck getting a torque wrench on some of the plugs with the engine in the car - especially the one behind the power steering pump
Old Jun 6, 2007 | 08:02 PM
C4S993's Avatar
C4S993
I have long skinny piano fingers and so #6 was no big deal, I had more problems renewing the lower valve cover bolts with B+B headers onboard. For the #6 plug I used a socket with an elbow that was machined to the socket and a 2 inch extension and that did the trick. Remember that old Porsche tool kit spark plug tool ? I found it inferior to the above set up. Thanks, Patrick
Old Jun 7, 2007 | 03:09 PM
Rick Lee's Avatar
Rick Lee
That vacuum unit was no problem coming out on my car, but it took some work to get it back in. Mine was a little gummed up, but not like yours. Still, before replacing it, I'd clean it all up real good with brake cleaner or whatever, maybe spray some WD-40 on it when it's all clean and then reinstall. I haven't had any problems since.
Old Jun 7, 2007 | 08:10 PM
C4S993's Avatar
C4S993
Thanks Rick, I got the two 10mm bolts off but what is hanging it up ? Is the linkage the problem ?
Are there more bolts ?
Thanks, Patrick
Old Jun 7, 2007 | 10:22 PM
Rick Lee's Avatar
Rick Lee
Nope, just two bolts and two hoses. Takes some careful wiggling though.
Old Jun 9, 2007 | 09:34 PM
C4S993's Avatar
C4S993
Default I got it off !
Hot dame, it's off...thanks ! I cleaned it and it appears to working fine, should I just stick it back on or get a new one ? Thanks again, Patrick
File Type: jpg
File Type: jpg
