Fabspeed Supercup sound clips wanted
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
My pre-cat 02 sensors are installed...the post cat O2 sensors are secured with tie wrap...I had better look to see if they are grounded.
The best part about the cat bypass pipes, the incredible sound. It takes me back to my old hot rod days. A 993 with cat bypass pipes simply sounds evil, especially on idle, believe it or not.
My only concern is passing PA inspections, emissions, etc. Will the cat bypass pipes cuase any problems surrounding this?
If not, it is something I will seriously consider.
This car sounds HOT!!!!
http://www.youtube.com/watch?v=tjgps6LSTaM
Will the DACH X pipes sound similar with stock mufflers?
Chris from DACH X will get back to you...suggest you contact him personally. I strongly suspect you will NOT pass emissions testing with Cat Bypass pipes. I know I am putting my cats back on
When you fire it up for the Inspector, the Cat will be out of the Bag (Pardon the Pun; I couldn't help myself), I suspect. Note, I have not heard cat bypass with stock mufflers.
I don't drive my car on public roads so I suffer NOT from Green Guilt.
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Is Dach X a Rennlist Sponsor?
And finally, one will not pass emissions with the by pass. Our 200 cell cat pipes would though
the fiberglass packed removable inserts have been replaced by CC Inserts
Originally Posted by sidned
Dave - what are CC Inserts? Where do I get them? My fibreglass packed inserts need repacking and I don't know anywhere that sells the fibreglass sheets they use.
