Will 996 GT2 Wheels fit a WB 993?
I know the 996tt wheels will work.
Just curious about the offsets, the offsets on a GT2 are a little different than the 996tt, as well as being a little wider.
Fronts -- 8.5"x18" et 40mm
Rears -- 12"x18" et 45mm
Will they work on a WB 993?
8.5" should be ~ET50 ET 40 might work as long as ride height isn't too low but they7 stick outboard more than normal
![](http://members.rennlist.com/1976c38/993front_wheel_fit.gif)
Dave are you sure your 9 is 40? I have 9ET52 front and can't see anything sticking out further being able to fit.
samurai_k (06-21-2019)
They will fit. The rears need aggressive fender rolling. I'm not sure about rolling the fronts. Rob King, the owner of Scargo, has (or had) a set on his car. It looked pretty good.
Greg H.
Greg H.
