Thoughts on partial oil changes?
Anyway - it took me about 3 hours, which included going to get an oil filter wrench. I absolutely could not remove the 2nd oil filter without a wrench. I think I could do the whole task in 60-90 minutes the 2nd time.
Here's my question: you can drain about 8 of the 10.5 quarts of oil by simply removing the little access panel in front of the rear passenger wheel.
For low annual mileage, non-raced cars, is it ever acceptable to simply drain 8 quarts of oil without changing both filters and draining all 10 1/2 quarts of oil?
For example, I'm only putting about 2800 miles a year on my car right now. Certainly the filters aren't "used up" in that amount of time? Certainly the oil isn't used up either. However, due to moisture, etc, I understand you don't want to leave the same oil in your car for 2-3 years.
Can I just drain most of the oil perhaps every other time? I could do that in about 5 minutes.
What is the generally accepted practice?
Thanks!
I've changed mine twice since buying the car and admit that it's a long process. But you also know it's done correctly. I probably do between 3,000 and 6,000 miles per year.
Andreas
When I just changed my oil, it still looked virtually new - still clear on my fingers rather than black. Heck - I don't know. Seems like I just wasted two perfectly good oil filters.
I'm not concerned about saving $30 for filters though.
http://p-car.com/diy/changeoil/
One warning would be not to pull the oil pressure relief plug since I've seen a bunch of posts on that. I have only changed my oil once in my 993 and I am not sure where that is.
* 3 cans of Mobile 1 5w-50 one-gal at COSTCO, Taipei = US$23 x 3 = US$69
* 2 oil filters at DJ Motor 911, Taipei = US$25 x 2 = US$50 (made in Germany, good stuff)
* K&N air filter washed clean by DJ Motor, full SOP checks on brake fluid, ATF, tires, lights etc.
* Total labor cost at DJ Motor 911 = US$33
Above total = US$152
Save the old oil and use it in your SUV!
Sam's Club here in South Florida is selling Mobil 1 for $29.50 a Six Pack!
That's lower than it was 10 years ago!
Chris
Changing your oil and filters too often is a waste of both time and money. It's very possible that your filters have plenty of life left in them, but your oil is worn out, in which case, a quick drain and refill makes perfect sense.
How much on your cab? I need to move my 91 Targa first though.
Also what are the dates of the '08 Parade? I will be making my first vacation picks for 2008 soon and wnat to block that time frame. (2 weeks for me to match one week of my wife's time - I have odd days off)
I think a lot of us have problems getting past the ""3 mos. or 3,000 mi." frame of mind from the past. That was good for the oil cos. (and Jiffy Lube shops) but is overkill and wasteful. Understand I'm talking about full synthetic oil, not full dino oil.
Keep in mind, I'm NOT talking about cars that get tracked, that's another situation entirely.
I do take issue w/ BMW's current service schedule of every 15 - 20k (whenever the service light comes on), I think that is far too long between changes.
JMHO, TIFWIW, YMMV, DHMBIB ect.
I have a full change with both filters done (at a cost of $180.00) every year even with only a 5000mi per yr avg., that's only $15.00 per month for the peace of mind it brings me, which in my book is a great value.
ZP44
I have been in love with this exact car since I drove it when it was brand spankin' new in 1995 at a PCA Performance driving school when it belonged to the original owner (my student).
Now that I'm the second owner and have my dream car, seems normal for me to lavish expensive care on what I obsessed on for over 10 years.
ZP44
Given the mileage you stated, I think it's fine to simply change oil ...but do it right! Were I you, I'd swap out my Mobil1 yearly, but definitely change the large oil filter. The simple reason is that it takes no more than another 5 minutes to do if you're already draining oil from the tank plug. It's too cheap and easy to replace and not worth avoiding, IMHO.
I'd feel completely fine leaving the small oil filter in there and replace that, say, every other year ...putting you at what, 6K mile change interval?!! Factory recommends 15K on the large filter, 30K on the small. While I wouldn't go that long, I think you're well within that parameter
FWIW, I put maybe 10K miles/year on my 993. I change oil (Mobil1) every 7-8K along with the main (large) filter, and replace the small filter every other change ...again, that's a 15K interval where the factory recommends 30K so I feel very comfortable that I'm still overmaintaining my baby
