Thoughts on partial oil changes?
Weathergirl
I'd feel completely fine leaving the small oil filter in there and replace that, say, every other year
Addicted Specialist
From my understanding, the large oil filter is considered the "main" filter for the engine oil. The small one is for filtering the oil to the heads, more specifically the valve train because of the tight tolerances in the hydraulic lash adjusters. From this I presume far less oil flows through this filter media, which suggests why the factory allows an interval twice as long.
My feeling on this matter is that 12-15K miles on a filter "designed" (and I use that term loosely) to filter at 30K mile intervals still offers a comfortable "cleaning margin," if you will.
If there is anyone with direct knowledge on this issue of the small filter's task and longevity, I'd be glad to hear it as I am in no way expressing any points based on hard data.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Edward
Edward
Both filters are full-flow filters, with all of the oil passing through each filter. One filter is in the scavenge circuit (large) while the other is in the pressure circuit (small). The size difference is likely due to the fact that the first filter usually traps more contaminants than the second filter. With syn oil, don't wait for it to turn "black" like dino oil, as it won't.
Once you shorten the factory recommended interval for oil (15k) and filter(30k) changes, it is up to the individual as to where to stop. I too find it interesting to see the rationalizations explained.
Originally Posted by ZombiePorsche44
I'm always amazed at the logic of trying to save a small amount of money on an uber important low cost service when the car really deserves better and a full rebuild is in the neighborhood of 15K.
I have a full change with both filters done (at a cost of $180.00) every year even with only a 5000mi per yr avg., that's only $15.00 per month for the peace of mind it brings me, which in my book is a great value.
ZP44
ZP44
Maybe it's just that I'm not hung up on replacing something that doesn't need replacing, it has nothing to do w/ the cost of filters.
I just went through all of this discussion in my head and went ahead and changed the oil and both filters on my 993C4S. It had been more than a year, far less than the recommended miles but I was not comfortable with the time
between changes. I live in an area where it's often hard to get the car up to full temps, even after driving for a while. I assume I'm getting some condensation in the oil as a result. Also, look at the oil system diagram
in the factory manual. That little filter is in a fairly important part of the oil system. If I'm reading the manual correctly, it's in the system that also includes the lifters, the cam spray bar and the crank squirters. Is that correct?
If so, why not change that filter everytime you change the other one. It's not
that big a deal, get the right wrench, remove the rubber ducting hose and the
oil return line and you are there.
I agree there is no point in wasting money on oil and filters too frequently but I've always thought that on cars that get driven less than frequently, may not always get up to full temps- change the oil at least once a year.
Found my Mobil 1 15-50 at Target, not cheap but at least they have it.
Originally Posted by 993BillW
And so you're saying that by not changing the filters every time on a car that gets 3,000 mi. between changes that we're shortening the lifetime of our engines? Do you have proof of that?
Originally Posted by Bull
Then why change the synthetic oil at 3,000 miles, or do you believe it needs replacing?
Addicted Specialist
FWIW, it's generally accepted (by many wrenches, if you take stock in that sort of thing) that low annual-mile/low-use cars should have their oil changed annually, regardless of mileage. Water content from unburned condensation is no good for the load-bearing surfaces within the engine, nor is it good for the other contaminants from the combustion process to just float around. So even though the oil is often not "used up" in the strict sense, it is no longer as "useful" (or maybe "effective" is better) as it was.
Edward
Edward
Edward
Edward
FWIW, when my wife's new 328 comes in I'll not only replace the oil/filter after the first 1,500 mi. (not covered) but also change the oil (at least) every 7,500 mi. (again not covered).
I'm thinking about getting a '02 M3 for a daily driver/DE car but if the PO has only done BMW's recommended maint. I'm not sure I'd want to buy it.
The oil quality can be seriously affected by repeatedly making short trips , even if the milage builds up over a year .
The 911 loves at least a 20 mile trip to get the oil/motor right up to temperature and give the motor internals a good clean out - boils the water off .
Bottom line is that oil / filter change based on annual mileage should have how much long trip mileage is part of the equation !
Geoff
KS400200 , the oldest 964 on Rennlist , unless you know differently !
Geoff
I change everything every 5k.
However, I will be talking with Chris W. next time I decide to do this because at $300 (parts/labor; $100 for oil & filters/$193 for indie labor) I need to learn how to do this myself. I also find myself driving the car more and more. I don't understand how anyone can have one of these and only drive it 6k/year or less. That's just me though, to each his or her own. I've wanted one ever since I was a little boy, and now that I have one, I intend to enjoy it. I never put her on the road for less than 20 minutes, and always take the long, long way home just to have more seat time.
Addicted Specialist
... BMW seems to be moving away from this, at least w/ regard to their "free" scheduled maint. From what I've heard they won't do the oil change unless the "oil service" light is on....
Edward
Our family car is a '97 BMW 540i that we bought with 30K miles, now has 130K.
Transmission fluid never changed, as it is lifetime fill, and operates perfectly.
Engine oil changed per the service light, which is 12 to 15K, with Mobil1.
Have never needed to add oil between oil changes.
Technical Guru
BMW is not alone in this. More and more manufacturers are going with longer service intervals. Reason is simple: cost.
