Free 993 stuff! - UPDATED - ALL GONE!
OK, so it's finally time to get rid of some of the stock stuff from my car that's been lying around the garage. Before it hits the trash, I thought I'd see if anyone here wants anything. There's lots of suspension stuff (aside from the shocks, which I tossed but can still dig out of the trash) and a shift rod. It's all in good condition, just some dirt and cosmoline here and there. I went to Pelican's website and got all the part numbers for you guys (some of these things are surprisingly pricey!). PM me/email me if you want anything, you just gotta pay for the actual shipping...
Front Springs - 964 343 531 111 504 - GONE
Front Rubber Bump Stop - 964 343 301 00 - GONE
Front Shock Bellows (Boots) - 993 343 505 00 - GONE
Front Strut Plate (Top, I think) - 964 343 507 00 - GONE
Front Strut Plate (Bottom, I think) - 964 343 503 00 - GONE
Rear Springs (marked yellow I think) - 993 333 531 185 04 - GONE
Rear Shock Rubber Buffer - 993 333 105 00 - GONE
Rear Shock Bellows (Boots) - 993 333 107 01 - GONE
Rear Spring Base - 993 333 504 00 - GONE
Rear Spring Adjust Sleeve (3mm) - 993 333 511 00 - GONE
Rear Shock Support Mount - 993 333 110 01 - GONE
Front Sway Bar (20mm) - 993 343 707 04 - GONE
Front Stabilizer Bushings (20mm) - 964 343 792 20 - GONE
Front Sway Bar Mounting Clips - 964 343 777 80 - GONE
Rear Sway Bar (18mm, I think) - 993 333 701 01 - GONE
Rear Sway Bar Bushings (18mm, I think) - 477 411 313 B - GONE
Rear Drop Links - 993 333 073 02 - GONE
Shift Rod - 993 424 02 000 - GONE
??? Maybe "Bearing Body"? It's the second smaller
piece of the shift rod assembly - 993 424 219 0R - GONE
Rubber Boot - 993 424 294 00 - GONE
OK, that's it right now. I doubt anyone will want this stuff, but at least I tried!!!
Originally Posted by ZombiePorsche44
gonzilla,
I believe that the 94 and early 95 993's came equipped with 21mm front & 18mm rear sway bars and mid & late 95 on were equipped with 20mm front & 17mm rears.
ZP44
ZP44
