993 Forum 1995-1998
Sponsored by: DashLynx
OBC Rev Counter Display Repair
Old 05-17-2007, 04:19 PM
GabiOsz
GabiOsz's Avatar
Question OBC Rev Counter Display Repair
Hi,
I have obtained a spare Rev Counter with OBC dispaly from a friend who's display went on the blink, he bought a new one and has since sold the car, so has given it to me. Mine is fine for the moment apart from the odd flicker, but I'd like to repair it just in case.
I have changed the bulb, but short of removing my steering wheel and swaping them over, is there a quick way to test the display? Maybe applying voltage to certain pins on the gauge or something?
Cheers.
Old 05-17-2007, 11:05 PM
rwestervelt
rwestervelt's Avatar
I do not know the answer to your question, but I have to say that your 993 is stunning - rich muscle.
Old 08-02-2007, 12:49 AM
C4 NLW
C4 NLW's Avatar
Default Flickering OBC
I just wondered whether or not you found a solution to the slight flicker on your OBC display. I have an issue with mine. It works fine for a while and then periodically the digits on the display don't display properly. A quick tap on the guage face and the numbers come back to life.
Any ideas???
Old 08-02-2007, 12:53 AM
MarkD
MarkD's Avatar
Any ideas???
I have the exact same issue and a tap on the gauge clears it up. I suspect a loose solder joint that I will never be able to track down.
If I ever figure it out I will certainly share.... hopefully someone has already been there?
So far all I have found in searches is a replacement at approx. $1K.
Old 08-02-2007, 12:59 AM
C4 NLW
C4 NLW's Avatar
Well, thanks for the response. At least I am not alone. If I ever find a fix I then likewise I will let you know.
Old 08-02-2007, 04:27 AM
GabiOsz
GabiOsz's Avatar
Sorry, I really havn't had much of a problem with it recently and so haven't got around to fixing the spare.
Old 08-02-2007, 04:31 AM
C4 NLW
C4 NLW's Avatar
Ok, thanks for the comeback. I'll keep you in the loop should anything turn up.
Old 08-02-2007, 05:11 PM
Caveman
Caveman's Avatar
Hi Gabi,
I managed to track down a (UK) specialist that reckons they can repair the intermittent lighting on the computer display. I can dig out the contact details if you want them. They said the turnaround time was six weeks.
Cheers,
David
Old 08-02-2007, 07:20 PM
GabiOsz
GabiOsz's Avatar
David,
That would be great! Thank you.
Old 08-02-2007, 10:18 PM
C4 NLW
C4 NLW's Avatar
David,
If you wouldn't mind looping me in on the details as well I would very much appreciate it.
Thanks . . ......
Old 08-03-2007, 10:02 AM
Caveman
Caveman's Avatar
Wink
Here you go. It is Speedy Cables and there details are as follows:
Registered Address: Abercrave, Swansea SA9 1SQ
Company Reg. No 1200130 VAT Reg No. GB234519175
Tel: +44 (0)1639 732213 & (0)1639 732299 Fax: +44 (0)1639 732238
Email:- instruments@speedycables.com or cables@speedycables.com
I keep meaning to do this but it means taking the rev counter out and then just having a hole in the dash for six weeks...
Old 08-03-2007, 10:16 AM
C4 NLW
C4 NLW's Avatar
Great, thanks for the heads up on this contact. Very much appreciated.
Old 08-03-2007, 07:02 PM
billa77
billa77's Avatar
Adrian Streather "Porsche 993 the essential companion" writes:
OBC orange rear light flashing all the time Transistor BS170 on the superior printed circuit (CPU board) faulty.
OBC digital display failed short circuit on Diode 1N4118 located on the inferior printed circuit (LCD array) of the OBC.
Warning: The steering wheel needs to be dismounted in order to take the OBC out. There should be DIY here that describe this operation so please read first. Disconnect the battery at least 15 minutes before and shorten the + and - wires so that there is no remaining energy in the cars circuits, because of the Airbag mounted on the steering wheel.
Hope this helps...
Old 08-03-2007, 07:15 PM
Caveman
Caveman's Avatar
Thanks for the input. When you say "shorten" do you mean touch them together? Just checking! How easy is it to identify this diode?
Cheers,
David
Old 08-03-2007, 07:54 PM
billa77
billa77's Avatar
Yes touch them together to avoid any remaining energy in the circuit. Radio for example...
In a german porsche forum they also check for loose solder joint which seem quit common...
For the Diode 1N4118 location i cant help you much since i have no photo of the boards for the moment. This is not so super integrated circuit stuff as they produce today. Search on Google for Diode 1N4118 and you see how that diode looks like and purchase one in an electronics shop and if you are not familiar with soldering etc. find somebody or send the unit to fhp-chiptuning.de.
They repair for fixed costs of 129€ and offer this service very often on ebay in germany.
Quick Reply: OBC Rev Counter Display Repair
