Big fan of the 993
I have always been a huge fan of the 993, especially the looks which I'm sure many of you will agree. Recently I have started my search for the 993 and came across two 1995 C2s. As I'm coming from the 996 GT3, other than the usual, can anyone tell me what problems to look for when I inspect and test drive the cars? TIA for any input.
IMHO, the '95s have some advantages being ODBI cars and won't set a CEL for the 'dreaded' SIA port issue.
Some upsides:
- OBD I (easier to located / build a decent code reader)
- does not set a CEL when SAI ports are plugged (does not seem to be a performance issue when plugged)
Some of the downsides:
- lower power output being pre vario-ram
- rear suspension suseptible to wag, plamed for some track crashes (about $2500 to replace all parts with 96+ components)
I'm sure there are many other things to consider. As far as stuff to look out for? Uh.. door check condition, ratteling hydraulic lifters/followers, does it have the steering brace installed (req. for 18"+ wheels) .
Fun cars, that's for sure!
Some upsides:
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Hey John,
You may want to check out the post from 5/9 called '1995 vs 96-98 993's' here in this forum, should be helpful.
Also, the I have found some of the best research is to go to the place on the PCA tech site where 993s are discussed and spend time pouring through all of the problems folks have w/ their cars...you will begin to see a lot of recurring themes, especially in the 'suspension' and 'engine' categories. Also, there are some good things to note in the 'Other' section I believe, where they discuss what to look for when buying.
Hope this helps, Rick
The rear suspension IMO should not be listed as a factual problem, I own 2 95's and have yet to have the problems that some have reported. Both have been driven hard on the track... On this one I think the jury is big time out...
Originally Posted by DJF1
The power difference is mainly in the low end torque. Otherwise not much of a difference despite the posted factory figures. Besides the varioram models are 42lbs heavier than the 95 due to the weight of that varioram intake.
My '95 *feels* a hell of a light lighter than my '90 does. 42lb + for the Varioram? WOW! That's a lot of weight. I'll take me few less low-end ft/lb.
Are the 993s available in Taiwan U.S. spec or Euro-spec like here in Hong Kong? If they are Euro-spec then if John L is referring to a MY95, that is equivalent to the MY96 stateside since the 993 was introduced as a 1994 model outside of the U.S. and Canada IIRC. Also I thought that all Euro-spec cars are OBDI...isn't it only U.S. cars that are OBDII from MY1996 onwards? Can anyone confirm this?
I may be in the silent minority here, but I have a hard time going backwards in car technology. Some day I may upgrade to a 996 GT3 OR TT. No rush though as the love afair with the 993 continues. Maybe it'll even be a 997 when the time comes to pull the trigger. Who knows.
Good luck with your search.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
check for:
suspension
cel
rust (esp by windhsield)
leakdown and compr (if you get to PPI)
check that all the stickers are where they are supposed to be
leaks, steering rack
obviously, make sure there is a history of good maintenance, and talk to whomever did the work if you can.
figure out if there are any must have options (that could also make car harder to find or more $$). Some people love the sport seats, some don't, for example.
figure out if you like the S wide butts or narrow butts. You will pay more for the widebody cars.
The 2S is a wide C2. The 4S has big red brakes, AWD from tt, susp from tt. Weighs a little more, but not much that 2S.
you are better off if you find a car with the suspension already done. Other nice mods are done by many of us, include turbo s ducts, aux oil coolers, front protection bars, etc.
You'll pay a premuim for low miles cars, and S cars (though, frankly, a 2K mile car is not worh it in my opinion, unless you are going to display it and not drive it). Are they any better? Nah, just the 4S adds I noted above, but if you are not tracking it, who cares? It is just an aesthetic difference.
Have fun.
suspension
cel
Have fun.
