993 Forum 1995-1998
Brake pads/rotors
Old 05-13-2007, 09:36 PM
jclanin
jclanin's Avatar
Default Brake pads/rotors
Hello all,
It's time for a complete brake job on my 993. I'm going to do it myself (never done this before) and I need to go ahead and order parts. I'm going to do Zimmerman cross drilled rotors and Pagid pads.
Can someone point me in the right direcion on part #'s and where to order from - I'm in Atlanta.
many thanks!
--JC
Old 05-13-2007, 09:44 PM
DaveM993
DaveM993's Avatar
Not many folks on this board are fans of the Zimmerman rotors....
Old 05-13-2007, 09:52 PM
993inNC
993inNC's Avatar
Do you track the car? Great pad, cheap rotor. If no track time or very limited (or none) just go with factory parts (Textar pads/O.E. rotors). Pagids will squeal like a bitch and wear the rotors alot quicker (but the noise will get to you first
Old 05-13-2007, 11:54 PM
TMc993
TMc993's Avatar
Here's the Original Porsche Parts (Textar, etc.) list for everything but the anti-squeal spiders. I didn't put those back in when I did my brakes. If you haven't already got a Motive pressure bleeder, I've got one you're welcome to borrow if you don't mind the drive up GA 400.
A lot of folks here order from Sunset Porsche. Their prices are significantly better than any Atlanta dealership. I ordered from Sucoast Porsche in Sarasota (Talk to Rick Knab) and their prices were very close to Sunset (which I didn't know about when I ordered my parts) and were hundreds of dollars better than Atlanta dealerships (There's a comparison posted somwhere under my handle).
Here's the list:
993-351-043-01 BRAKE DISC (1)
993-351-044-01 BRAKE DISC(1)
993-352-041-02 BRAKE DISC (2)
993-351-939-01 BRAKE PAD SET (1)
965-352-939-04 BRAKE PAD SET (1)
999-067-041-09 SCKT SCREW 12 (4)
900-378-068-09 HXHD SCREW 12 (4)
Good luck!
TMc
Old 05-14-2007, 12:16 AM
jdistefa
jdistefa's Avatar
Don't buy Zimmerman, go OEM - especially with the discount through Sunset.
Old 05-14-2007, 01:01 AM
Mark in Baltimore
Mark in Baltimore's Avatar
Originally Posted by jdistefa
+1
+1. Just say no to Zimmermans.
Old 05-14-2007, 01:12 AM
fast_freddy
fast_freddy's Avatar
I just ordered OE Porsche rotors, pads, sensors, etc. through Sunset and it wound up cheaper than Zimmermans.
Old 05-14-2007, 01:51 AM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
I bought Zimmermans once.....never again!
Marc
Old 05-14-2007, 02:03 AM
Mike J
Mike J's Avatar
I am running Zimmermans with zero problems...and I have tracked the car. I might just be lucky?
Old 05-14-2007, 02:32 AM
David Ray
David Ray's Avatar
I have a set of used OEM rotors and brand new Textar pads for 250.00 + shipping. All four (4) corners.
Old 05-14-2007, 08:39 AM
jclanin
jclanin's Avatar
Here's the list:
Good luck!
TMc
Thanks Terry!
Question (and probably a dumb one) - Why are two of the brake discs different part #'s and two are the same?
I'll definitely stay away from Zimmermans - I don't track the car and don't plan to... I do drive moderately aggresive although probably not compared to alot of the guys here. My goal is to have very good stopping power and minimal dust/squeal.
--JC
Old 05-14-2007, 09:24 AM
95FL993CAB
95FL993CAB's Avatar
David
PM sent.
Old 05-14-2007, 09:38 AM
AOW162435
Seared
AOW162435's Avatar
The front rotors are side-specific while the rears are interchangeable.
Another vote for Sunset
Andreas
Old 05-14-2007, 10:06 AM
TMc993
TMc993's Avatar
JC,
One other thing about parts....When I did my brakes, I removed the brake pad sensors and tied them off. If you are going to maintain the stock set-up you may need to order those sensors. Some folks here have posted that they have been able to re-use the existing sensors while others have had problems doing so.
I had planned to do away with mine all along, but out of curiousity tried to remove them intact....It was impossible and I destroyed them getting them out.
Also, I have a set of four good jack stands if you need them.
TMc
Old 05-14-2007, 04:56 PM
Land Jet
Land Jet's Avatar
I just ordered a steering rack brace from Sunset, and asked if they wanted my PCA membership number. They said no, they have a better deal. They sell parts at 15% over wholesale
Quick Reply: Brake pads/rotors
