Yet another - will these fit? (rims)
King of Cool
Originally Posted by allill
Finn,
How often do you go through rubber with that much negative camber?
I haven't really paid attention on mileage but I just replaced the rears that from outside were still ok (not much thread but still on the borderline of being ok) but inside were totallyu corded, with metal showing.
I think it might be wirth swap tyres from left to right but haven't though about that yet.
Track tyres wear pretty evenly since the driving is much more aggressive.
Weathergirl
Not sure what you mean by "lack of bump steer"
a steering feel fanatic
Thank you to all the Rennlisters who helped with the above information.
I just "pulled the trigger" and bought them!
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Now to learn about tires.... (Any references to threads or suggested search terms?)
I'm currently running P-zeros on my CupIIs. Only because the PO had those on the front and I needed tires for the rears when I bought the car.
Your tire choices will also depend on what camber you are running and also whether you will roll your fenders, but generally for 10" you can use 265-295 and 225-245 for 8.5". I like PS2s but they fit a little wider than my previous SO3s, don't come in 285/30 and the 245 size is hard to come by. Given your concern about rubbing with the more aggressive offset, you could run the PS2 in 275/35 in the rear with 235/40 up front...both these sizes will work with your new rims and this combo will dial out some of your understeer.
Congrats, those are some great looking wheels.
I've recently done quite a bit of research on tire brands here on RL and by speaking with tire dealers and guys at AX etc. At the end of the whole excercise, my conclusion is that PS2s are the best way to go for DD. Best feedback and best performance in different temps and conditions. The downsides are cost and durability. I guess for people to give you better opinions on tires, you might want to specify what you expect from your tires, what the use is going to be and what conditions you'll be driving under.
PS - The wider offset actually tuned out some of the bump steer and makes the car feel more planted. The nervousness that our cars are prone to at high speeds on long sweeps has been greatly reduced after the spacers were installed.
I can tell you what not to buy if you are worried about fitment. The Michelin Pilot Sport Ribs, which are otherwise very good tires (Viken used to love them), have a "rib" that protects the rim lip that protrudes out beyond the sidewall, making the tire a bit wider at that point than it otherwise would. I have no rubbing yet, but the extension of the rib makes the tires look too wide for my car.
