HKplus splitters...not so bad
I was there when we installed those splitter and my IMHO they are looking good for one reason I believe . The reason being they were prep and painted at Korva which I know that Boris will work with what he has and make it look good but that being said the quality of the product was not top notch . There was square hole for the drain hose missing ect..
So what David in LA said is what I suspect will happen even without hitting them :
"Louis - That looks pretty good. I had Hong Kong-sourced aftermarket fiberglass splitters on my white cab previously. The only big issue I had with the aftermarket stuff (besides work required to make them fit) was that they were fiberglass so after a few hard scrapes and bumps the paint developed hairline fractures (which show up on white paint) and the fiberglass layers on the bottom eventually splintered."
Unless Korva`s "magic " holds up I believe after one season a person would not be too happy with the look .. This is MY opinion only and say this to repeat what Louis said in the first place " nothing beats OEM . Basically you get what you pay for and hope for the best .
Cheers Guy
Cheers Guy
