900-123-095-30 seal washer bad P/N?
Saw this part on Robin's oil change DIY as the correct engine drain plug crush washer for '96 up. Called Sunset this morning to try to order it, and they said "no go."
Double checked with Pelican and is / was a valid #, but that's it and maybe no longer stocked.
Does that mean that V-ram cars run two of the larger 900-123-118-30 washers?
Seared
If I remember correctly, the same aluminum washer is used for the tranny drain plug. Call Jeff Clark @ Sunset and just tell him that you are doing an oil change. He'll get the right washers to you without an issue. I've ordered these a few times from him already.
Andreas
Andreas
I have reused these washers with no problems so don't sweat it...you can replace them next time around if you are so inclined....
Cheers,
Mike
Cheers,
Mike
Technical Guru
