Drop Link popped off - fixable??
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I am sure it would pop back on, but at this point, the plastic bushing or 'race' is bruised at a minimum. Replace it.
It appears the reason it popped out is the clocking on that perch. Needs to be pointing towards the inside of the car, not so much towards the back end of the car.
Jeff, I would replace it.
I have posted at the end of Jeff's DIY, a small comment.
After replacing the drop link, with the right clocking of the link, loosen the sway bar from both sides to do this,
and tighten the sway bar bushings, with the car on its four wheels on the floor, after installing the drop links. you have to put the car over a car well (hole).
This is also explained in the DIY--but you need to make sure that when the car is weighted, the link is vertical so that any suspension movement will load the sway bar directly from above, rather than exerting a twisting motion.
If you get any twisting, you will either snap the drop link (pictured above) or loosen the spring perch.
Unweighted, there will be a slight tilting toward the rear, but the key is straight when the suspension is weighted.
(R25.) Install the new drop links between the ends of the rear sway bar and the drop link bracket extending from the Bilstein HD shock using a 15mm socket and a 16mm wrench positioned between the drop link and the rear sway bar. Do not completely tighten.
TIP: It is critical that the rear drop links are properly positioned and tighten, including the drop link bracket on the Bilstein HD shocks. Although it is possible to generally set the drop link orientation with the vehicle raised, it is easier to lower the rear of the car to put weight on the rear wheels. While doing so, you will then want to position the rear drop links and drop link brackets on the Bilstein HD shocks so that the end of the drop link bracket is in the same plane as the end of the rear sway bar when viewed directly from below. Once this is achieved, the rear drop links and drop link bracket/locking collar can be tightened. Proper positioning of these drop links ensure that the rear drop links do not break, twist, or contact the rear suspension components while driving.
