Engine Smoke
Engine Smoke
I just recently had the oil changed and added a cat bypass. Now this is probably unrelated but just in case I though I should mention it. I have developed blue smoke at idle, now it is very inconsistent, some times it smokes and others it does not, and it only come from the passenger side exhaust pipe. Only on an idle, I had a coworker follow me and said that there no smoke under hard acceleration, between shifts or on throttle lift. just wondering if it could something other then valve guides or rings? weird that it does not do it all the time
hmm... i *think* that is also a sign of an overfill.. When the car is good and hot what is the oil level on the dipstick? you mentioned this JUST started happening post oil change?
Technical Guru
Originally Posted by only993
I just recently had the oil changed... I have developed blue smoke at idle, now it is very inconsistent, some times it smokes and others it does not, and it only come from the passenger side exhaust pipe. Only on an idle, I had a coworker follow me and said that there no smoke under hard acceleration, between shifts or on throttle lift. just wondering if it could something other then valve guides or rings? weird that it does not do it all the time
When your oil temperature is at ~194F/90C and with the engine speed at idle for at least 60 seconds and running on level ground how high is your oil level?
Normally (unless they are completely shot) whatever makes its way past the piston rings or the valve guides usually ends up burned/converted by the catalytic converters but now that you have removed those, the smoke is just dumped out the tail pipes.
Jason, would you please explain the temperature gauge, line system that Porsche uses. The top red area is obviously overheating, but what does each line mean in fahrenheit degrees? Thanks.
BTW, I decided to bite the bullet and go with the auxiliary oil cooler because of the SC. Thanks for your input.
Originally Posted by 993inNC
Its pretty normal with a by-pass pipe. You are seeing all the crap that the cats filter out. Most likely coming from valve guide "blow by". Unless you oil consumption is excessive, I wouldn't worry about it, especially if it only happens either randomly or just at idle when cold.
I had some smoke when I added the cat bypass. You can ask Chris. So I change my oil and I called a tech. He mentioned to me that is the most over looked item on these cars with oil level. He told me to run the oil level no more than half way on the twisty on the oil stick (do not go over). I have not had a problem since and I have great oil pressure that right at the 2 mark. My 2 cents.
Technical Guru
Originally Posted by coltj
Why is your oil pressure so low, even at normal idle?
Has anyone experienced problems with the fan override? Two mechanics that I trust (one in SoCal, the other in NorCal) both advise against it - in their opinions the risks (damage to fan, damage to electrical system, etc.) associated with constantly running the high speed fan outweighs the potential benefits.
Technical Guru
Keeping the engine cool is the best thing you can do for it (other than clean oil) so the fan switch is a great addition. It just a way of getting ahead of any heat spikes ; if you know its going to be hot you can switch on the fan and let it stop the upward creep of the temperature. We would not have to do this if Porsche did not put in a thermostat switch that opened at too high a temperature.
Cheers,
Mike
Cheers,
Mike
