993 Forum 1995-1998
Sponsored by: DashLynx
Mothers Power Ball
Old 03-31-2007, 09:20 PM
allill
allill's Avatar
Default Mothers Power Ball
I did a search and came up with two threads so I figured I'd ask.
Has anyone tried Mothers Power Ball? Does anyone know of any other similar products? My wheels could use a polishing and I wanted to see if there were any users that have used it.
Old 03-31-2007, 10:19 PM
allill
allill's Avatar
I saw that, the "mini". They also have a "mini md" on their website. Man, it's amazing what they can charge for a cut up nerf softball ain't it? I might go and see if there's a kit or gift set available at kragen.
Old 03-31-2007, 10:26 PM
Smiles
Smiles's Avatar
From what little I know, the Mother's ball has high amounts of ammonia and other chemicals that clean quickly, but also invite further corrosion to happen sooner.
I've found that great products, and great advice, can be had at www.englishcustompolishing.com.
-Matt
Old 03-31-2007, 10:31 PM
allill
allill's Avatar
Smiles, What product would you suggest?
Old 04-01-2007, 01:11 AM
tj90
tj90's Avatar
I just bought the mini power ball today at Kragens for $19.99. Im finding that it is working okay, but be careful of the sharp metal heat shields that are inner sides of the rotor. It will cut up the nerf ball. I think it is a decent product but I would not say its a miracle - "man how did I live without it" - type product.
Old 04-01-2007, 01:24 AM
Mark in Baltimore
Mark in Baltimore's Avatar
With my Fikse FM-10 polished rims, I get better results by using Wenol red. The mini powerball that I have is still too large to get inbetween the small, narrow areas.
Old 04-01-2007, 02:06 AM
allill
allill's Avatar
let me google wenol red
Old 04-01-2007, 02:45 AM
allill
allill's Avatar
Mark,
Do you just use a rag or some type of drill attatchment?
Old 04-01-2007, 09:20 AM
Land Jet
Land Jet's Avatar
The Flitz polishing type ball is made of felt and much more resilient. I paid $25 but figure it will outlast 10 powerballs.
Old 04-01-2007, 09:38 AM
jcoll1
jcoll1's Avatar
check out Autopia.org, they should have plenty of info on the detailing just about anything!
Old 04-02-2007, 09:52 AM
Smiles
Smiles's Avatar
It depends on how agreesive your polishing needs to be. It's similar to using different polishes on paint. You might need to get more agreesive on oxidized surfaces, or you might just need a more mild, routine polish.
There's a decent description here:
http://www.englishcustompolishing.co...utomotive.html
Also, here's what you need to know about polishing:
http://www.englishcustompolishing.com/usca/myths.html
There really is some great advice there if you can patiently go through each link.
But, to answer the question, I'd use whatever ball you like (or already have) with the one they call, funnily enough, "Trucker’s Blend".
I have no affiliation, by the way.
--Matt
Old 04-02-2007, 01:35 PM
Mark in Baltimore
Jeff,
I just use a rag with the Wenol. Works pretty well. If I want to get really crazy and achieve a mirror-like finish, I use a polishing wheel on my drill. I have four wheels for various grades of polish/cleaners, all available from Lowes or HD.
Old 05-02-2007, 10:42 PM
allill
allill's Avatar
Ok, I went and got a mother's power ball mini. I had to try it. Results are good and my hands don't need to feel the burn of hand rubbing the metal anymore. The power ball and mother's liquid polish did away the light stains that were on the rims (the rims weren't tarnished or anything to begin with) and you can definitly see a difference. The best part of this ball is that it doesn't have an exposed metal nut or bolt in the very front of it- it's clad in rubber or plastic and also has the foam material of the ball surrounding so you don't scratch your rims.
Sorry, no before and after shots.
It now only takes a couple minutes per rim instead of who knows how long. I do want to try it with other polishes such as wenol if that stuff isn't too abrasive.
Old 05-02-2007, 11:22 PM
LT1
LT1's Avatar
I use the mini to polish my watches--they come out brand new!
Old 05-03-2007, 12:30 AM
allill
allill's Avatar
What polish do you use and what watches do you polish? I have a Breitling with a high polished surface which I can probably use any polish that I'd use on my polished hre's, but on other watches that have grain such as Rolex, I don't think I'd want to polish them with anything too abrasive as it may result in losing the grain of the stainless.
Quick Reply: Mothers Power Ball
