RS splitter install
Mar 30, 2007 | 04:45 AM
RS splitter install
I've had a pair of these lying around, and I'll paint them over the weekend. are they a PITA to install or is it an after work jobbie ?
Thanks,
Peter R.
Mar 30, 2007 | 07:02 AM
The OEM version is very easy to install. You will also need to fit new plastic wheel well covers.
Mar 30, 2007 | 08:13 AM
Are you referring to the wheelarch liners ? I didn't have a clue. I'll have to source some of those first then.
Peter R.
Mar 30, 2007 | 08:29 AM
Exactly. The bottom of the wheelarch liner will not fit the RS Splitter. I odered a couple new pieces when I fit my RS Splitters. I cut the existing spliters to fit and I put the new ones away. I will refit the new liners if I decide to return to the stock splitters. I believe I paid $45 a piece for the liners.
Mar 30, 2007 | 08:37 AM
Ah, so I need to cut OFF a piece of the liner to fit the RS splitter ? That sounds much easier than having to cut one ON.
Thanks,
Peter R.
Mar 30, 2007 | 08:48 AM
Peter,
Where did you get your splitters? Are they fiberglass or the flex resin type?
Ron
Mar 30, 2007 | 09:14 AM
King of Cool Rennlist Member
Mar 30, 2007 | 09:17 AM
Quote:
Originally Posted by 95FL993CAB
Peter,
Ron
A second hand parts dealer in holland. They are the OEM part, not fiberglass. Bloody expensive as well. About 450$.
Peter R.
Mar 30, 2007 | 10:34 AM
mounting the factory splitters is not a big deal, the liner just needs minor mods
here's a detail of the RS splitter/wheel well liner junction
Mar 30, 2007 | 10:43 AM
Thanks for the pic, Bill.
Peter R.
