stumped by a nutsert
The TSB for installation of the CDC-3 CD changer lists a nutsert for installation into the front trunk so I obediently drove around to the Porsche dealer and acquired the requisite number of nutserts.
I guess I expected a nylon or springy metal mount that I would pound in the 9mm holes I'm supposed to drill but instead it's just a little threaded barrel with a small lip. nothing to keep it from pulling out of the hole and nothing to keep it from spinning when any pressure is applied.
So do I
--epoxy it into the hole?
--take it back to the dealer?
--something else?
So do I
--something else?
In the absence of which you ca use an appropriate sized bolt and a nut to compress the 'nutsert'.
Thread nut onto bolt part of the way. Set nutsert (the name !). Thread bolt with attached nut into nutsert hole. Tighten nut agaist nutsert (aaaaaaaarggghhhhhhhhh) while holding bolt with spanner. Keep tightening nut untill RIVSERT is suitably compressed.
If you do not understand how this works, ask someone who does, or you'll be guaranteed to screw it up in the fullest sense of the word.
Peter R.
Peter R.
