993 Forum 1995-1998
GT3 Installation
Old Mar 21, 2007 | 06:26 PM
jkb157's Avatar
jkb157
Default GT3 Installation
I just recieved a pair of GT3 seats from Gert for my 95 993.The sliders that gert sent look 996 but he states they will work in a 993.Gert forgot to send me a hard copy of the directions that show the modificaton I need to do to make the seats fit.I know others have done this update so I was hoping I can get some help.Also has anyone done this update and used a anti-sub belt attachment to the seat.I am trying avoid drilling for this belt.Thanks
Old Mar 21, 2007 | 07:15 PM
viperbob's Avatar
viperbob
Former Vendor
Yes they will work, but you will be sitting about an inch and a half higher than you are now.
Old Mar 21, 2007 | 10:03 PM
Mark in Baltimore's Avatar
Mark in Baltimore
That's what I've found out, too.
Old Mar 21, 2007 | 10:42 PM
CWay27's Avatar
CWay27
In order to fit the seats with 996 hardware, you must;
- Bend the front tabs to make them sit flush with the rails.
- cut guide pins at the rear of sliders. Don't worry cause you don't have them on stock seats.
There are some ways to lower the seats using 996 hardware but not for every one.
Good luck
Old Mar 21, 2007 | 11:08 PM
Mark in Baltimore
FWIW, I never had to do any of this futzing around.
Old Mar 22, 2007 | 09:16 AM
Lawrence_P's Avatar
Lawrence_P
Use the aftermarket generic Recaro sliders (without height adjustment) and you won't lose any headroom.
Old Mar 22, 2007 | 12:28 PM
ppressle's Avatar
ppressle
I believe the brey krause side plates help with the headroom.
I used the bk sub strap bar bolted to the sliders. Works well, with no drilling required for the sub straps.
Pete
Old Mar 23, 2007 | 02:32 PM
IamSMC's Avatar
IamSMC
I thought there was a 993 specific sliders available to mount the GT3 seats in a 993?
Old Mar 23, 2007 | 02:34 PM
IamSMC's Avatar
IamSMC
Meaning if your directly bolt in the 996 sliders directly into a 993?
Old Mar 23, 2007 | 03:04 PM
Mark in Baltimore
Yes.
Old Mar 26, 2007 | 02:55 AM
IamSMC's Avatar
IamSMC
On this thread:
https://rennlist.com/forums/showthre...ight=gt3+seats
I ask a question regarding the side mounts:
https://rennlist.com/forums/showpost...55&postcount=7
Thx
