Varioram Transplant into a '95
Is this just totally crazy? Anybody heard it being done? I'm guessing you'll need to find a donor OBD II and other assorted wiring. Mmmm....dealing with the LA Dismantler...good times!
Or can you just add the Varioram intake during the re-build of your '95 block?
Wonder if a 150,000 mile '95 3.6 is worth anything as a core charge?
Why would you do this? Drive both the 95's and 96+'s first so see if its worth it to you. Its pretty weird but each 993 car that I drive feels different..often a 95 feels just a strong as a 96+, sometimes not.
You will need the associated plumbing and DME to drive the Varioram, it would be easier to swap the entire motor/DME or get another car.
If you troll the posts the 95 appears to be attractive to a lot of people because the ODBI does not sense any problems with the SAI system (the engine still has the system though). I would stick to a 95 and rebuild the motor if it needs it. Is the motor blown? (top end or bottom too? At 150,000 miles you might need to re-ring, piece of cake if the heads are off..). The 95's are more easy for a DIY rebuild since the cam timing is more likely to be the old style which a DIYer can just time with a dial guage.
Cheers,
Mike
Cheers,
Mike
Originally Posted by Mark in Baltimore
Kim Ouye aka Wreck Me Otter performed this mod to his 3.8 Yellow Zonker, IIRC. Look for his posts or PM him.
RL Technical Advisor
We've done one of these conversions on a '95 3.8 motor and tested the results, back-to-back on our engine dyno. On this motor, we found a 20-22 lb-ft difference
from above idle to 5K. After that, the torque curves merged and above 5500, there was no measurable difference to 6800 which was as far as we tested to, given the RS cams.
IMHO, for a car with a good set of close-ratio gears, there is no difference when used on the track. For street use where one spends more time between idle and 5K, it may be worth the effort; it really depends on how you drive.
Rally-Jon's suggestion to aquire a Euro OBD-I V-Ram engine is pretty good since those retain your 55-pin ECU harness. Better yet, the installation of the V-Ram M64-20 3.8 RS engine which is OBD-I,...
Should you pursue this, I do not think you will have any trouble finding a home for your existing 3.6.
Yes, the parts all bolt on, it's not a complicated deal to do so. As Steve pointed out for street use w/ stock gearing it's probably worth it.
The other way to do it is w/ a RoW vram, also easy to do and you don't have to deal w/ SAI. Of course the emissions ***** may have something to say about it too.
I went w/ the latter route
Are all ROW engines vram or did they make MYs with non-vram like our 95s?
Do the ROW vrams crank the 282HP that US vrams put out?
Sorry for the newbie questions but just want to confirm...
Bump...
*the exception is 993RS which had vram in '95
Thanks Bill...you're a great resource.
